Sony Bravia KDL-40Z4500 hdmi not working anymore
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Hi guys!
    I have this old but gold 40" Z4500 Sony Bravia LCD TV that had the first issue with HDMI1 port after a couple of years I bought it (in 2008): I connected a cable from an Xbox 360 to HDMI1 and something went wrong, because from that moment HDMI1 port stopped to work. No audio and black screen appeared.
    A couple of weeks ago HDMI2 port also stopped working: I used it connected to my PC with a DVI to HDMI cable. Now, like for HDMI1 port, I have no audio and no video in it. And it's a shame because HDMI2 was the only port to support analog audio in.
    Now only lateral HDMI3 port works and I have to use it with a multi HDMI switch.
    What can I try to do to fix these issues?
    Thanks in advance for the reply!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Sony Bravia KDL-40Z4500 hdmi not working anymore
    Was the XBOX powered on when you plugged in the HDMI cable ?
    Have you checked with a magnifier/microscope for physical damage to the ports ?
    Can we see photos of the mainboard and can you indicate which is the working port.
    • DS-1
      • Jun 2015
      • 82
      • Italy
      I don't remember if Xbox 360 was powered or not, it was a lot of years ago, but I remember that, after that situation, I always turned off tv and external boxes before plugging/unplugging HDMI cables. Then I would say: yes, it was powered.
      I've checked ports for physical damages and I've found nothing that makes me believe that the ports are physically broken.
      The picture is showing a board like mine: the two ports (HDMI1 and HDMI2) in the red square are not working, the one in green square (HDMI3) is working.
      • diif
        • Feb 2014
        • 6978
        • England
        All three HDMI go to a CXB1444R before going to the processor. It's either that or a component(s) near the "red box" HDMI ports.
        • DS-1
          • Jun 2015
          • 82
          • Italy
          Thanks a lot for the reply!!!
          Do you believe that CXB1444R could be damaged, even if one of the three ports works?
          Also, I'll try to find what component(s) can be damaged near the "red box".
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
          • justin35
            Sony bravia kdl-43w755c - boot loop
            by justin35
            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
            from what i read online it looks to be an emmc issue…
            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
            i took out the board and say an samsung 16gb emmc
            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
            i could try to put one instead of the 16gb one, but will it work?
            where do i get the software from?
            any help will be much appreciated!...
            03-06-2024, 12:26 PM
            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
            10-16-2024, 05:15 AM
          • Spc.
            Sony Bravia KD43XF7596BAEP - Android no picture
            by Spc.
            Greetings everyone.
            I also have Sony Bravia, model:
            Sony Bravia KD43XF7596BAEP - Android.
            What happend is that image dissapeared while we were watching tv.
            Diagnostics:
            1. TV turns on, no errors
            2. Backlight turs on, no errors
            3. Power indicator turns on, white color, no errors
            4. Menu works on android, you can hear sound while switching channels
            5. Volume up and down works via TV remote and via buttons
            6. Tunner works, HEVC / MPEG-4 decoder works
            7. I get audio from channels
            8. No picture is present,...
            05-19-2022, 04:28 AM
          • KYBOSH
            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
            by KYBOSH
            Previous owner said TV just went blank one day.
            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
            I just downloaded the Sony KD-75X7800F Service Manual and...
            11-19-2024, 10:12 AM
