Sharp LC50LE752E no picture and backlight, indicator light is lit
  • roy.zhero
    • Sep 2020
    • 4
    • Netherlands
    I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
    When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
    When I hold the force-on-combination it will turn on. It then shows a perfect screen without glitches. After powering it off with the remote the indicator light turns red. I can power it on again via remote. But after 10 minutes of inactivity I noticed the screen had turned off again while the indicator light was still blue.
    Troubleshooting:
    Measured power supply pins:
    Power supply connector going to main board:
    1 (N.C.): 0
    2 (ERR): 0
    3 (PWM): 3.64
    4 (BL_ON): 0
    5 (PS_ON): 3.285
    6 (GND): 0
    7 (GND): 0
    8 (5.75V): 5.88
    9 (5.75V): 5.88
    10 (GND): 0
    11 (GND): 0
    12 (12V): 11.97
    13 (18V): 17.79
    14 (5Vs): 5.18
    Backlight connector going to backlight board:
    1 (24V): 23.98
    2 (24V): 23.98
    3 (24V): 23.98
    4 (24V): 23.98
    5 (24V): 23.98
    6 (GND): 0
    7 (GND): 0
    8 (GND): 0
    9 (GND): 0
    10 (GND): 0
    11 (ERR): 0
    12 (BLON): 0
    13 (N.C.): 0
    14 (PWM): 3.64
    There is no backlight_on voltage. There is never any voltage on ERR during boot.
    Manually shorting the Backlight on with the Power supply on lights the backlight normally and will stay on as long as I short it. All sides will light up.
    I have reseated all connectors going between the boards.
    I noticed pressing the touchbuttons on the TV does not work, nothing happens. Even when I forced it on it did not respond however the remote works normally when the TV is forced on.
    The main board is DUNTKG135FM08.
    The power supply board is RDENCA459WJQZ.
    Board diagrams in PDF:
    https://1drv.ms/b/s!AkpE6xgs6VHNhGNwakvV
    I have uploaded photos of the main board and the power supply board.
    I am guessing there is a problem with the main chip or the standby chip IC3800. I'm not sure where to go from here. Any help is appreciated.
  • roy.zhero
    • Sep 2020
    • 4
    • Netherlands
    Re: Sharp LC50LE752E no picture and backlight, indicator light is lit
    Working link to board diagrams:
    https://1drv.ms/b/s!AkpE6xgs6VHNhGPi...rNn3R?e=O5Mh3S
    • Diah
      • Feb 2013
      • 6504
      glitch at SPI Flash.. try freez or heat the spi flash if the set start to turn on.. then need to dump it and write it on new spi
      • roy.zhero
        • Sep 2020
        • 4
        • Netherlands
        Thank you for your reply Diah.
        Due to travel I have only been able to test it yesterday.
        I identified 3 memory chips (IC3501, IC3502, IC3503) and used freeze spray on all of them and tried to turn the TV on (1st attempt). Unfortunately no change. Tried the freeze spray on the standby chip as well (IC3800)(2nd attempt) as well as the complete region of that side of the main board (3rd attempt). No change in any of the attempts.
        What other things could the culprit be?
          • 12317
          • U.S.
          Sometimes you have to freeze the crap out of them to get results.
          • ItepK
            LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
            by ItepK
            Hello everyone! I've found this television, and I began troubleshooting it.
            First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
            I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
            After the recapping, all the voltages stableized, however, the issue in the title still remains.
            I could...
            01-03-2025, 09:01 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • PNI E.
            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
            by PNI E.
            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
            02-20-2025, 08:36 AM
