Hello friends, please i need help. some guys just messd up this tv by removing some igbt mosfet , so am having issue knowing the right component. can anyone who have very good insight about this tv tell me the real numbers and positions of the mosfets in the ysus board.
lg 42pt350r plasma
Re: lg 42pt350r plasma
30F124 and IRG71C28U are used, I have two of these tvs here because the "technician" that touched them destroyed the boards.
Information I found on the internet is:
Q708 Q709 - IRG71C28U
Q713 Q703 - 30F124
Q711 Q710 - FDP33N25
IC701 - ADUM1234
IC702 IC703 IC711 - FAN73711
The ADUM and FAN rarely fail.
The IRG are 600V high current IGBTs, I've read on forums about 30J127 and RJP63F3 could be used in their places, but there are slim chances of buying any of those that wouldn't be a fake.Last edited by Biruslapio; 09-16-2020, 02:54 PM.Comment
I don't know if it's originally on this board, because both of mine had all the IGBTs missing too, but all the repair kits use the IRG intead of 30J124 or 30J127, and the brazilian forum I've read multiple users said that the board comes with IRGs.Last edited by Biruslapio; 09-18-2020, 01:45 PM.Comment
none of them are working, and they won't for a long time until I can get a Y-SUS replacement because the dumbass that messed with them ripped all the traces out.
If the IGBTs or MOSFETs are defective, there will be a short between their pins, measuring at max 100 OHMs, pretty easy to spot the failure at these Y-SUS boards, the problem is getting original parts to replace with.Comment
It has perfect image for a few minutes then blow up? probably counterfeit IGBTs, what are you replacing them with?
Chech the heatsinks for overheat, they probably can handle the peak voltage but not the current, this is why they fail.Last edited by Biruslapio; 09-19-2020, 04:51 PM.Comment
by angelosHello Guys,
I am not familiar at all with plasma tv's but i tried my luck anyway since business is so bad. We gotta try, right?
Anyway, the original problem was a tv clicking and not starting due to a short circuit on the Z-Sustain board (on the right side from the rear).
I found two transistors shorted (30F123) and changed the gate driver ic's as well. I think they were FAN73711. I soldered for dry joint on power supply, Y-Sustain and Z-sustain. Started up the TV and the short was gone so i had an image but.....
Lots of colorful speckles on the image and also there... -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by KYBOSHPicked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
No picture but you hear the TV static (white noise) playing loud and clear.
The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
But it seems they didn't get too far and just left it.
When I first took a look I was amazed at how pristine the inside looked.
Its as if the TV had been in a time capsule.
Caps looked like they were just pulled off the self.
Copper coils had no sign of corrosion on... -
by chazhThis is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,... - Loading...
