mosfet ,diode, igbt ,ect equivalents
  • jimbofz
    • Apr 2013
    • 539
    • uk
    im trying to find database of semiconductor equivalents ,the lg y sus board EBR75455701 lg60ph670v
    im struggling to find replacement parts for
    ive read on here not to trust some mosfet ,igbt type rjp30h2a, k8a60da from China
    as they work ,run hot ,then blow
    im in uk and e bay is full of cheap copies
    can anyone suggest a reliable supplier thanks
    • 21586
    Re: mosfet ,diode, igbt ,ect equivalents
    farnell and rs
    https://uk.farnell.com/
    https://uk.rs-online.com/web/
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Looks like they both are out of those. These parts are getting pretty scarce as they are considered obsolete. UT source has alot of used parts and are guaranteed to work. I have used parts from my own scraped TV's sometimes. It all depends on the reason they failed(bad ground screws{Panasonic} lead free solder fractures {every brand of tv} or others).
      • jimbofz
        • Apr 2013
        • 539
        • uk
        Originally posted by SMDFlea
        both of these do not have the parts in stock ,and i dont trust the chinese copies to last
        thanks
        • jimbofz
          • Apr 2013
          • 539
          • uk
          thanks
          ive gone through my scrap y sus boards but no luck ,
          futher cold checks ,i found ic 402 ,type; p155e s/c
          cathode to deck pin3 to pin 4
          its a shame theres no repair kit for this panel
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • Nooy
            VGA MOSfet permanently shorted and loss of MOSfet pad
            by Nooy
            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
            02-14-2024, 02:26 AM
          • redbaron1007
            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
            by redbaron1007
            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
            09-09-2025, 11:10 AM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
