These are the ones I've found, hope it helps
Philips 55PUS6262/12 always ON but no picture
Re: Philips 55PUS6262/12 always ON but no picture
Right, I've finally been able to measure a bit more and taken some pictures as well.
I've focused on the black connector on the PS board which goes directly to the main board.
The results are like this:
Left row:
On/Off: 3,25V
NC: 2,95V
GND: has contact with chassis
+12V_A: 12,0V
+12V: 12,0V
+12V: 12,0V
+3,5V: 0V
Right row:
DIM: 2,4V
PS_ON: 3,0V
+12V_A: 12,0V
+12V: 12,0V
+12V: 12,0V
+3,5V: 0VAttached Filesif you find these attachements useful please consider making a small donation to the site
A good starting point is to give the voltage readings of the two connectors. Remember there are two rows of pins. Give the connector name then the pin number, pin name, voltage read.
Some pictures of your boards would also be useful.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hm I have a serial number if that helps?Attached Filesif you find these attachements useful please consider making a small donation to the site
Pin for activating p.s. is ps_on. Put there + 5v (max.).Leave a comment:
What is the chasis number of this type ?Leave a comment:
Hello!
So I was given a broken LED-TV with some unusual issues.
When I plug it in, it turns on and stays on, and does not respond at all.
The red standby light never comes on, it just switches on the backlight LED's and just stays that way.
The mainboard has a couple of green LED's that comes on and stays on, and I can't visually see any swollen or burnt components anywhere.
I replaced the T-con board to no awail and now I have started measuring voltages, but electronics on this level is above my knowledge.
The only clue I have is when I measure the voltages on the connector for the mainboard on the PSU-board, I am missing the 3,5V on both of the lower pins in the black connector in the pic below. I've tried applying 3,3V via an external power supply, but no change.
Any ideas?Attached Filesif you find these attachements useful please consider making a small donation to the site
Tags: None
by Patrick501Hello,
I'd like to repair a Philips 55PUS6704.
It turns on and you can see the backlight, hear the sound but no picture.
When I disconnect one of the T-con cables, half of the screen turns white.
right cable disconnected= right side white
left cable disconnected= left side white
When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
Also you can notice one single... -
by RauniHello, this is my first post on this forum, and my first attempted to repair a TV.
My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
Read also that we should test what happens if we... -
by SchwoinHey everyone,
the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
you can see them on the top half of the photo.
At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
by madyoyoHI.
I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming.... -
by mrsithHi. I have seen a thread with this TV model, but the solution wasn't applicable to my set unfortunately.
I got the set very cheap with problems on the right side of display - it was flickering and fuzzy with whitish noise. After a bit of play I have noticed that the set is fine with only left LVDS plugged in - but, unless I pressed the LVDS connector (on either side which is strange), there were some purple artifacts appearing. Decided to replace T-Con with both LVDS tapes (suspected bad tapes). After replacing them - same effect, with purple artifacts disappearing when pressing... - Loading...
