Vizio p602-ub3
  • charlie555
    • Feb 2018
    • 76
    • usa
    Vizio p602-ub3
    no standby light, when I press the on button logo appears and the the standby light fades away. I did find a cap swollen, but replaced it and still the same. main board or power supply? no sound
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Vizio p602-ub3
    If you found one, there's probably more that have failed.
    • charlie555
      • Feb 2018
      • 76
      • usa
      Re: Vizio p602-ub3
      I tested ps on and got 5 volts at the main board connection, but when I removed connection from ps to main board I have zero volts from ps on power supply. ps right?
      • charlie555
        • Feb 2018
        • 76
        • usa
        Re: Vizio p602-ub3
        now getting 15 blinks
        • bunting78
          Vizio D650i-B2 wont trun on and no standby light
          by bunting78
          First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
          09-23-2021, 08:53 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
        • brithepi2k
          Sony KD-65XE8596 no standby light
          by brithepi2k
          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
          cheers...
          09-06-2025, 02:22 PM
        • Kaar3l
          Samsung QLED QE65Q7FNAT only standby light
          by Kaar3l
          TV: Samsung QLED QE65Q7FNAT
          PSU: BN4400940A
          MB: BN94-12832K
          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
          09-24-2024, 01:35 PM
