Samsung UA65
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Samsung UA65
    Hi Guys
    Got a samsung UA65ju6000 (possibly UN65 ) set is dead if i remove thw plug between Main and power boards, the LEDS light up.
    With that plug out the voltage coming from the PSU is 13 volts (as printed on the board. When I plug in the main board this voltage drops to 9 volts.
    Also , There is no stand by light .and i cannot find a 3.3 volt anywhere on the board. I also find that D201 meaasures short circuit.
    I reckon the fault must be the Main Board. but any input will be greatly appreciated
    Thanks James
    Power board is BN44-00805a and Main board is BN94 09544B
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UA65
    Some pictures of your circuit boards would be helpfull. Is D201 on the main board or power supply. If on the power supply then I would replace it and then check your voltages again.
    The 3.3V could be coming back off the mainboard.
    • provider10
      • Mar 2016
      • 52
      • South Africa
      Re: Samsung UA65
      Thanks for the reply.
      The diode is on the main board
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: Samsung UA65
        Can you post some nice sharp pictures of your power suppy board and the mainboard showing where D201 is located.
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • Lee M.
          Samsung UN75RU8000FXZA bad main board?
          by Lee M.
          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
          11-08-2023, 07:46 PM
