Re: Hisense F42K20E static out of speakers even with sound turned down
WOW, i do not believe this. I cleaned the power supply board up and down, with tooth brush, rubbing alcohol, canned air and finally a leaf blower, and the static is 95% gone!! The only way you can hear it now is if you put your ear very close to the speaker (but that is probably normal).
I really can't believe this worked! You guys are AWESOME!! Thanks for the help everyone!
i noticed the noise has breaks like something is charging up then discharging then repeating etc etc .. could well well be corrosion or dust . as said above give it a good cleaning ..simple free things first . . i might scope the power supply or sub in a known clean supply for the audio .Leave a comment:
I there a input switching IC, or do all the inputs go to the main IC? IS the main IC something like MSD blah blah...Leave a comment:
this noise are static . it may caused by the dust (dirt you have on all boards) .first you need to clean all boards up and down sides. panel tabs ..sockets... with high pressure airLeave a comment:
does the audio ic chip get hot ?
on another note try disconnecting speakers and try headphones again .
i am however thinking it could be a power supply issue .Leave a comment:
Since the speakers has their own amplifiers to drive the speakers, the headphone also has its own amplifiers circuit, and both of them and both channels are making the same noise so it has to be something common to both of them.
Does the this TV have audio line outs through RCA jacks, try and see if the noise is there also.
How about when you set it to MUTE, does the noise go away?Leave a comment:
Yeah it's the same sound on all the inputs, in fact the sound does not stop even when switching input, it is constant. Also tried a factory reset and it didn't fix it.Leave a comment:
check all the other inputs and the tuner for the static noise. Maybe to a factory reset too.Leave a comment:
Yes I also get normal audio out along with the static. The static is very loud so even at high volume you can still hear itLeave a comment:
https://www.badcaps.net/forum/attach...4&d=1597787583
The Class D amplifier chip is in the bottom left of the board where the speakers connector is, you see 4 black round inductors to the left of the IC, and two Lytics caps to the right of the IC.
Does this TV have headphone output and if it does, do you get noise on the Headphone jack also?Last edited by jmandawg; 08-20-2020, 04:38 AM.Leave a comment:
not familiar with that noise ... do you get normal audio over the top of it ?Leave a comment:
Does this TV have headphone output and if it does, do you get noise on the Headphone jack also?Leave a comment:
probably the main board since sound is made there... how ever it could be "dirty power" coming from the power but I doubt that because then you would like have other issues. If you post good medium close of the main board in and around where the speaker outputs are on the main (going to the internal speakers), someone may recognize some of the chips involved which may get you some "hints".Leave a comment:
would that be on the main board or the power board?Leave a comment:
Ok... thanks for the clarification. sounds like you lost a capacitor on the audio circuit.Leave a comment:
I'm using no input at all, absolutely nothing is plugged into the TV, it's just the blue screen, and that static sound is blasting out the speakers.
I tried an hdmi souce, and it works, and i get the hdmi audio, but i also get the static.
Sorry I meant headphone jack. If i plug headphones into the headphone jack, the speakers turn off as expected (no static out of external speakers) but the static comes through the headphones.
I tried a factory reset, no difference.Leave a comment:
what input are you using and what are you inputting? what aux jack are you referring to, the manual doesn't refer to one? You could try a factory reset to see if any thing changes. Plug in a headset and what happens to the speakers / what happens in the headset?
what is the auto volume control set to?Last edited by budwich; 08-19-2020, 07:12 AM.Leave a comment:
Quick update, I just tested hooking a different speaker up to the output wire and i get the same static. The static also comes through the aux jack on the back of the TV.Last edited by jmandawg; 08-19-2020, 06:35 AM.Leave a comment:
Here you go, i had to zip it to be able to attach it.Attached FilesLeave a comment:
can you post a recording of the noise ?Leave a comment:
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by Comp_ProHello all,
I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU... -
by diggittHi,
I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you-
Hello to the forum.
My name is Christos, I am new to the forum here and i am posting from Greece.
So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
So i tried asking for a schematic from the company and they would not give me one. Instead they...-
This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:30 PM
- Loading...
