Panasonic TH-50AS700 - Can I rely on LED tester results?
  • senakahks
    • May 2020
    • 39
    • New Zealand
    Hi, I am new to TV repair and I have Panasonic TH-50AS700 TV to repair. It goes off when I change the HDMI cable or sometimes it goes off itself after some time, say half an hour. Once it goes off, the red bulb blinks continuously (should be a single blink) and can't turn on using the remote. When I turn off from the wall, it works again.
    I tested LEDs without opening the case by giving supply of a Chinese LED tester via a ribbon cable. all inputs yields the same voltage. Does that say all LED strips are good?
  • petehall347
    • Jan 2015
    • 4440
    Re: Panasonic TH-50AS700 - Can I rely on LED tester results?
    yes if the voltages equate to the amount of lamps times each ones normal running voltage
    example 20 lamps at 3v running voltage =60v . might not be dead on accurate reading on your tester .
    • Diah
      • Feb 2013
      • 6487
      LEDs function and test depend on currents not voltage.... Panasonic sickness with backlight are the sockets of the strings. many i found they burned out because of the heat,
      • petehall347
        • Jan 2015
        • 4440
        i have only just got one of those testers and it works like i said . say i test one 3v led it reads 3v .. if i test a string of 20 it reads 60v ..if i test a string of 20 with 3 shorted ones it reads about 50v .
          Does it stay on longer if you reduce backlights to 50% or less?
          The LED tester you have probably puts out 30mA not in the hundreds as in operation in TV.
          What inspection and Voltage testing have you done when TV works and when it does not work?
          Can we see the pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with?
          • neilc6
            • Nov 2015
            • 1550
            1 blink code on a Panasonic is bad backlight so you likely have an intermittent LED in the string that is failing at higher current than your LED tester can put out and when it warms up. Take Budm's advice and lower the backlight level to see if it stays on longer. Also turn off any ambient light sensor setting that could crank up the backlight in a bright room.
            • senakahks
              • May 2020
              • 39
              • New Zealand
              It was in 60 Backlight and I increased it to 100. It went off in about 10 min. Now doesn't come on and red light keep on blinking.
              An image of the boards of the TV we are working attached herewith.
              What kind of reading should I take?
              • neilc6
                • Nov 2015
                • 1550
                It looks like you caused an intermittent LED to fail completely by turning up the backlight level. Recheck your measurements with the LED tester. A one blink code can be confusing since it looks like its just blinking.
                • Diah
                  • Feb 2013
                  • 6487
                  in reality how would you know the string had 20 LEDs? mean you tear it down till the strings.. LED type and V if 3 or 6 or 4.7 V can know from the label no need this tester at least to me... i cant see the benefit of the tester.
                  as i said the currents play big roll. and in case if you have shorted LED with the tester other good LED at the strings will lid on ?? if yes.. mean with out tearing down you still have led come on so you cant see the one off... and if NO mean you need to tear it down and do test one by one to terminated the bad one.
                  • petehall347
                    • Jan 2015
                    • 4440
                    everyone has their own ways of doing things .
                    as i was always told voltage and current are related .
                    • Diah
                      • Feb 2013
                      • 6487
                      dear friend... i know how much you are exact talking. .. thanks
                      • senakahks
                        • May 2020
                        • 39
                        • New Zealand
                        Say if there are 4 output pairs from the PSU to backlight, if all pairs give the same voltage for LED tester, can't we predict that at lease at that particular moment strip sets are working equally? intermittent LED failure are a different case.
                          So at this point can you still get the TV to come on and stay on long enough for you to get to the user menu to be able to turn down the backlights level to as low as you can?
                          In post #1: When I turn off from the wall, it works again.
                          BTW, can I see good clear straight shots of the whole power supply/LED driver board?
                          • neilc6
                            • Nov 2015
                            • 1550
                            Intermittent LEDs are tougher to track down with a low current LED tester. Clues are slower to turn on, flickering, or reading higher or lower voltage. As indicated before, a basic LED tester puts out around 20-30mA while your TV will run at 300mA or more.
                            • senakahks
                              • May 2020
                              • 39
                              • New Zealand
                              Thank you for very useful explanations. I am planning to replace LED strips. Before doing that. I got reading from backlight connector using the LED tester (after disconnecting from driver).
                              1st pair: 28.1V
                              2nd pair: 28.2V
                              3rd pair: 28.2V
                              4th pair: 26.4V (about 2V difference)
                              5th pair: 28.2V
                              6th pair: 28.3V
                              The only issue is buying LEDs from this part of the world.
                              Can we make a dummy set of portable backlights (for different sizes) to make troubleshooting easy since replacing LED is a time consuming process?
                                That 4th pair looks suspicious. Try leaving the LED tester on that pair for a long time and see what happen to the Vf reading.
                                So the strip show about 28.2V Vf, driving the LED at 30mA will give 3V LED Vf of about 2.8V (or 5.6V for 6V LED), so the LED string has either ten 3V LEDs or five 6V (Dual LED) LED's.
                                If you have CV/CC bench power supply that can go up to 30V Min and min current of 300mA then you do true drive current through each LED string to test, start at 100mA first.
                                What is the LCD panel model number a shown on the sticker on the LCD panel.
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  I've found it difficult to find strips for Panasonic models. You can try Aliexpress but you need the part number off the strip. When I cant find strips, I repair the bad LED, move it to the edge in case of bright spots, and turn down the backlights but there is still a chance of repeat failures since all the leds have wear.
                                  • senakahks
                                    • May 2020
                                    • 39
                                    • New Zealand
                                    I opened the backlight and found that one LED is not working in 4th pair.
                                      So we can see the LED strips?
                                      How many LED does it have?
                                      • Andre Gilbert
                                        by Andre Gilbert
                                        11-20-2024, 08:52 PM
                                      • AquaMan Ua
                                        Problem with PANASONIC CF53 laptop after changing BIOS settings
                                        by AquaMan Ua
                                        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                        05-17-2025, 09:40 AM
                                      • howardc64
                                        Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                                        by howardc64
                                        Samsung have been using this style LED connector for few years now
                                        Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                                        The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                                        10-12-2025, 08:13 PM
                                      • Lifeisfun
                                        Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                        by Lifeisfun
                                        Hi folks!
                                        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                        Eventually I discovered that it was related to moving the laptop.
                                        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                        I removed the board got one of those memory slot testers...
                                        06-04-2025, 02:26 PM
                                      • stecos
                                        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                        by stecos
                                        Hi everyone!
                                        I happened several times, in the search for help from the web, to consult this very interesting forum.
                                        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                        Having said that I come to the gist of my post on the forum as the title suggests.
                                        For my passion for technology I'm now collecting several...
                                        11-28-2022, 11:39 AM
