Follow up on your success
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    There are way too many open/unresolved threads in the forum.
    If you have solved a problem, post the repair process. Or at least the end result(giving up or whatever).
    This will save endless new threads being started .
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Follow up on your success
    +10
    I agree that there appears to be an increase in threads left unresolved.
    If you ask for help and people have spend their time assisting surely the least you can do is close down your thread and give the reason why. Repaired, replaced the board, gave up.
    Others who have a similar fault and read an unclosed thread never know if you were successful or not.
    • jimbofz
      • Apr 2013
      • 539
      • uk
      very good idea
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4544
        • Italy - Milan
        This seems a global way of doing, the same almost in my country's forum, it's a sign of general fall of interest in the filed of repairings, i'm currently getting few tv and almost for free because them remain unsold when fixed, i suspect that also the market of new is not so active here.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          We're still seeing too many unresolved/unanswered/given up posts.
          If you come to a conclusion, with or without the community's help, finish the thread.
          DO NOT KEEP STARTING NEW ONES, OR HIJACKING EXISTING ONES!
          • DAVEMAC02
            Inverting op amp follow up
            by DAVEMAC02
            Follow up to my op amp diagram of Q208 FET and IC204 for NJM 2068M op amp. I took took the following DCV readings on the Q208 (2SK246) and IC204 pins:
            pin 1 0v, pin 2, 0v, pin 3 0v, pin 4 -15.6v, pin 5 0v, pin 6 .08, pin 7 0v, pin 8 +15.9v
            Q208 source -.006, gate -15.5v, drain -.102. These readings are from the op amp Q208 that has no output on pin 1. I don't know what state ie (On or Off ) Q208 should be when op amp is working correctly. This circuit is on the filter/limiter stage of the PA system. Any help is appreciated. Thanks
            10-03-2024, 01:08 PM
          • zomi
            Manual cof bonding success rate ?/ feedback wanted
            by zomi
            Just wanted to get some feedback,
            whats peoples' success rate with cof bonding repairs.....
            09-23-2024, 12:45 PM
          • valvashon
            Repair Success! Middle Atlantic UPS2200R-IP
            by valvashon
            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
            02-06-2024, 12:54 PM
          • Valtekken
            Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
            by Valtekken
            Specs:
            • CPU=AMD Ryzen 5 3500U
            • GPU=(integrated) Radeon Vega Mobile
            • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
            • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
            Hello everyone.
            My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
            A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
            09-10-2025, 04:14 PM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
