Remembered how to enter service menu. [tv on-volume down to 0-remote 9876-menu will appear] Made change LVDS map. But don't remember how to lock in change. Can someone tell me. thank you.
Element 32LE30Q Service menu
TCL LED TV Service Menu Code
LG LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by tusiimeThe current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance! -
by intercepterHi,
I have JVC LT-32CA120
Board:Vestel 17MB171
I need rotate screen.It is possible in service menu and how to enter service menu?
Thanks. -
by alltvrepairsHi,
I have just replaced led set of this vestel tv due to age.
I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
Thanks again.... - Loading...
