42PG20R Firmware issue
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Hi, This TV has corrupted firmware, first the TV would power up show a blue-ish static screen, some weird lines, sometimes the menu showed up all weird, and power down, locking up and accepting no more commands.
    Unplugged main and did the AUTO_GEN test, it displayed the patterns and worked fine, of course then the problem is with the main.
    Then I heated up IC802 and IC803 at the mainboard, since I don't have freeze spray at the moment, now it looks less corrupted but still shuts down in 10 seconds or less, I tried to do a service menu reset quickly before the shutdown, but it didn't change, also no idea if it actually worked.
    What I'm doubting here is which Flash chip should I replace, IC802 apparently contains some sort of BIOS within, and IC803 is the software of the TV, all that is sold around here for replacement is IC802, I can't find the flash dump of IC802 also.
    IC802 = ATMEL 24C64AN SU27
    IC803 = I can't read the label.
    The pictures are of front and back of the mainboard, and IC802/803 on the zoomed photo, the yellowed dark spots are flux, there was some minor oxidation that i got rid off.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: 42PG20R Firmware issue
    Update: I've bought 2 pieces of IC802 and IC803 each, they already were flashed with the proper dump since I couldn't find anything online to flash them myself.
    Nothing changed initially, the symptoms were > TV powers on by itself, the TV background (everything except the menus) would be all blue, purple, green, red, yellow, each time one color, then the TV would stop accepting remote input, picture freezes and weird verticals stripes would show, shut down, repeat.
    Then I started probind around the TV with an oscilloscope looking for noisy lines at filtering capacitors, all the rails except the PSU ones were noisy, but that apparently is normal on this TV, I was seeing some spikes on C1118 C1128 and C1110, searched at forums further and did what I should've done at first, replace the 100uF 16V SMD solid capacitors at the VRAM and other rails, this stopped the erratic behavior of shutdown and menu corruption, but the background is now green coloured and HDMI only shows messed up artifacts.
    I swapped IC802 once again and the TV finally worked, this is a universal issue on the whole XXLG and XXPG series from LG in 2008, every board has these capacitors start failing over years of use and introducing noise at the VRAM and EEPROM VCC, then when the TV shuts down it corrupts the IC802 flash contents and the image loses all their original config so a random color mix is selected as white, sometimes blue/red/green etc.
    The TV didn't last 1 hour before having another problem, the black turned to blue (even the menus), and vertical lines appeared at regular intervals on the screen, after wasting a lot of time replacing even more capacitors on the main board, I unplugged LVDS from main board and did the AUTO_GEN test, the blacks weren't blue, but the vertical lines appeared on the test, so I simply swapped the logic board with another one I luckily had lying around in better condition from a 42PG60D, it was identical except for the memory software version, this finally seemed to fix it, I could've also replaced the caps on the original logic board, but didn't bother with it.
    Messing with IC803 is useless, IC802 and the capacitors are where the issue lies. The .bin flash dumps for both of them are attached.
    Caps replaced:
    C1118 C1128 C1110 100uF 16V next to DDR chips.
    C1143 47uF 16V < Weren't necessary
    C1109 C1153 100uF 16V
    • zoltor
      Canon G3430 has a lightning flash after the firmware
      by zoltor
      Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
      09-17-2025, 12:40 AM
    • titomno2
      Surface Pro 7 type 1866 PD controller firmware issue
      by titomno2
      Hi guys,
      Hope you are fine.
      I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
      The boot time is so long (up to 5-10 minutes).
      After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
      I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
      In the past I have found that if the update is a success, the boot...
      04-27-2025, 01:02 AM
    • L36
      MSI GE 65 - 9SF - Bad flash issue
      by L36
      Hi All,
      Having an issue with a bricked MSI GE65 - Model 9SF. Bricked BIOS, did not do a full BIOS dump backup including ME region (rookie mistake). Resorted using to the latest BIOS available from MSI to flash the BIOS via CH341A for this laptop.
      Problem - I initially flashed a ME update that came out for this laptop as a separate update. Thus, before bricking the laptop the ME version was 12.0.94.2380. PMC version 300.2.11.1025 on the system. The MSI latest BIOS I'm trying to flash back via CH341A contains ME version 12.0.40.1433. PCM version 300.2.11.1024.
      The...
      02-27-2024, 10:11 AM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • ekozeko333
      [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
      by ekozeko333
      I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
      🔥 The Problem Started After Suspected ESD/PD Fault
      I experienced a power issue or ESD event through a USB-C charger
      After that, the NX20P5090 power switch was visibly burned and was replaced
      Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
