Can I Replace the Screen of 2 Different Model TCL TVs that Have Same Screen Size?
  • koolx
    • Jun 2020
    • 27
    Is it possible to take the display from a TCL 55S405 and replace the one in a TCL 55R625? Thrye both 55". I just want to replace the screen and make sure it fits.
  • nomoresonys
    • 12331
    • U.S.
    Re: Can I Replace the Screen of 2 Different Model TCL TVs that Have Same Screen Size?
    If you want help, KNOCK OFF the double threads, you have one going about this tv, you don't need more threads for the same tv, it just confuses things, just ask on original thread.
    • koolx
      • Jun 2020
      • 27
      ok cool
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • benek123
        RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
        by benek123
        I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
        The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
        When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
        I checked the EDID with the old screen - it is identical.
        What...
        09-24-2024, 03:28 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • ravi_1617
        HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
        by ravi_1617
        Hello to all ,
        I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
        Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
        on external VGA port image is perfect /normal , Attached image...
        07-25-2025, 12:07 AM
