looking for a source for a Diode for P65VT60 SC card
  • djw43
    • Mar 2015
    • 95
    I am attempting to repair the SC card in a P65VT60.
    I have found the transistors on ebay, but there is an elusive diode on the board that is shorted out that I can't find without waiting 5 weeks for a CHina delivery.
    The diode is:
    RFUH20T3S diode D401 on the board.
    I believe it is
    D16401
    panasonic part # B0FBCN000012
    even though I have looked extensively, I am open to suggestions.
    It's used in a handful of other panasonics.
    thanks,
    dave in NJ
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: looking for a source for a Diode for P65VT60 SC card
    Have you tested it out of circuit ? The 2 forward legs are tied together and will read as a short.
    • djw43
      • Mar 2015
      • 95
      thanks for the suggestion, on the 6 transistors and this diode, there was a short on all three combos of legs.
      1 to 2, 2 to 3 and 3 to 1, all shorts
        • 31184
        it's made by ROHM not Panasonic
        • djw43
          • Mar 2015
          • 95
          thanks, yes, I can buy it from ROHM but the shipping takes 5 weeks!
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            While on the board, the diode will test as a short. That's because the igbt's are shorted. Remove them first and your diode should be fine.
            • djw43
              • Mar 2015
              • 95
              haha!
              you are so right!
              Thank you Sir!
              • Christos Tsiligiannis
                Marian Trace Alpha sound card repair help
                by Christos Tsiligiannis
                Hello to the forum.
                My name is Christos, I am new to the forum here and i am posting from Greece.
                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                11-18-2024, 05:26 AM
              • Kemer
                Graphics Card mounting frame
                by Kemer
                Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                What worries me right now is the possibility that...
                09-14-2024, 08:57 AM
                HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                09-06-2024, 08:30 AM
              • FZG
                EVGA Nu Audio Sound Card - Not Working
                by FZG
                I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                I found...
                03-07-2025, 11:44 AM
              • benwaterson
                Gigabyte Aorus 1080ti - card not initialising
                by benwaterson
                Hi there.
                Have searched various forums but haven't come across the exact issue I am having.
                Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                02-05-2022, 11:42 AM
