Samsung Ue55ju6800kxxu
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hello all,I would like some advice,I have the above TV set,the screen is black with sound,I can see the image with a hand torch.
    Now I want look at the backlights,Which looking online are expensive,no doubt wil need the whole set.
    Right what is the best way to remove the glass panel without breakage,suction cups ? Will they break the screen or is there another way ? Assemble upside down ? Help please.
  • nomoresonys
    • 12323
    • U.S.
    Re: Samsung Ue55ju6800kxxu
    Tutorial there: https://www.youtube.com/watch?v=Dg2bNnqvwDk
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Hi all are the backlights universal ? in other 55 inch samsung tvs.
      • diif
        • Feb 2014
        • 6978
        • England
        The LEDs yes, but the strips they are mounted to are usually just for that model TV.
        V5DR_550SCA_R0 and V5DR_550SCB_R0 are the two part numbers for your strips.
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          How many strips do i need ? of each part number
          • diif
            • Feb 2014
            • 6978
            • England
            9 of each https://www.aliexpress.com/item/4000924520650.html
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              Can these be in other Samsung televisions if can find a donor set local to me can cut the cost,I’ve seen uE43MU6100k which lights up but smashed lcd,can anyone advise ?
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                Or UE48J6300AK
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  43" strips are not going to fit a 55". The only ones suitable are from any UE55JU68xx TV.
                  A complete new set for £42 delivered, I'd take a set of those over replacing individual failed LEDs.
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    Dont know if trust that web page tbh,abroad orders,dont custom fees apply
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      It depends on the value they declare, there might be a bit extra to pay (maybe £15). It's still far cheaper than buying a set from the UK.
                      Aliexpress is like ebay but cheaper and with a longer wait of between 2 weeks and 3 months. There is also buyer protection.
                      • LEEDASH
                        • Dec 2012
                        • 481
                        • Bedfordshire
                        sod it im going get a led tester i may not need the whole lot may be a few out,So I assume if one or two led on a row are out then the whole lot will be ?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          No, it can be just individual LEDs out on a strip. Sometimes I replace just individual LEDs but on some sets i wish I hadn't bothered as I takes to long, especially aligning the lenses correctly on some sets.
                          Although the rest haven't failed they will all have had the same hard life and you might end up having to replace some again within a short time.
                            Typical LED tester will only put out 30mA instead of hundreds of mA for true test, so the LED may light fine at 30mA but will fail at operating current which is 150mA and higher.
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              So basically the whole lot has to be changed and the strips are only for this brand and size of Samsung,no other Samsung 55 JU Range
                              • mmartell
                                • Oct 2013
                                • 3189
                                I've only ever changed out individual LEDs except for side lit strips I can't seem to replace those without making a complete mess of the strip...
                                The last fix I did was a 65" LG. The very next day another led burnt out so I had to do the whole thing over again. First time that's ever happened to me. Then I did a current mod and all good so far.
                                When people say it's best to replace all the strips with new ones I would agree that might be the best practice except that you are not likely to find NEW strips even though the guy on eBay claims they came from a new TV with a broken screen. In reality those strips could have been abused and on the verge of failing. I bought hundreds of individual LEDs from China for a few dollars and I'm happy to take my chances with those.
                                Just remember to turn the current down after the operation.
                                • nomoresonys
                                  • 12323
                                  • U.S.
                                  Looks like UN, UA and UE will work, probably need them to be from 55 inch screen to work if you're doing the whole strip ie.
                                  • LEEDASH
                                    • Dec 2012
                                    • 481
                                    • Bedfordshire
                                    nomoresonys is this a definite,100% if I get a ue,un,ua same size they will fit directly into mine,
                                    • LEEDASH
                                      • Dec 2012
                                      • 481
                                      • Bedfordshire
                                      https://www.ebay.co.uk/itm/samsung-t...4AAOSw9-9ewXtU
                                      • nomoresonys
                                        • 12323
                                        • U.S.
                                        Ok, double checked and they will work.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
