Philips 50PF7321/10 no image or sound
  • karsavuran
    • Jun 2020
    • Turkey
    Hi all, greetings from Turkey.
    I have an old Philips 50PF7321/10 and it stopped working.
    When I plug in I hear two relay clicks and after a few seconds I hear another one. Green light is on but no image or sound.
    I tried few things, here are the results:
    I dissconnect connectors of the X-Main and Y-Main boards from the PSU board and measured the voltages. All are OK. (I can post the readings if you want)
    When I connect them problem starts. Many voltages are missing or wrong and the led (LED8001) blinks 5 times. Alarm codes on the boards says Vscan for 5 but it was OK when X and Y boards was removed.
    When I connect them one by one the led stays steady but no image.
    The PSU board was completely replaced some time ago by the previous owner.
    I could not understand if the problem is on the PSU board or X or Y boards.
    Could you help me to find out the problem?
  • Kartowl
    philips 47pfl6158k/12 image faded away, sound still coming from TV
    by Kartowl
    Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
    04-23-2024, 12:57 AM
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • alro7779
    Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
    by alro7779
    Hello there!
    Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
    08-07-2025, 11:53 AM
  • domix
    Sony KD - 65XF9005 - No image, sound OK
    by domix
    at tv KD - 65XF9005 i have a problem.
    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
    is this a common problem for this tv?
    i attached pictures of inside. Supply board looks okey, no blowed caps....
    07-21-2025, 06:37 AM
