Hitachi 57SWX20B-- No picture
  • grungerokker13
    • Nov 2009
    • 4
    Problem: 57inch Hitachi 57SWX20B tv powers on but I get no picture.
    I can hear it power up and it "sounds" like a tv getting ready to come on with the clicks and the power supply booting up but the screen never comes up. I can hear it running and all the leds light up but it never gives a picture.
    I opened it up and I can see that no lights are coming out of the red/yellow/blue magnifying lights (i'm assuming that whole devise is the lamp).
    I'm a novice with projection screen tv's but I'm good with electronics and I would be better with this if I had schematics to see how this actually worked.
    My question is this: is this a bad cap somewhere (if so, how do I know where?) or is it a bad lamp or a bad projector?
    Any help or suggestions is VERY much appreciated. If you need me to do any further troubleshooting and report back I will do so.
    If nothing else, if someone could help explain exactly how these things function or give me a link to electronic schematic that would help too.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Hitachi 57SWX20B-- No picture
    Are the tube filaments lit? Look at the ends of the tubes you should see an orange glow.
    Magnifying lights? Those are the red, green, and blue CRTs. I'm sorry but I'd recommend getting a book about TV service first.
    RPTVs are alot more complicated than their direct view CRT cousins especially the video circuits.
    There is a host of things that can cause no picture.
    Off the top of my head shorted Horizontal Output Transistor, Bad Flyback (not supplying HV anode or filament voltages to tubes), bad Vertical Output IC (causing chassis shutdown or cutting CRT drive to save tubes from burnin).
    • Toasty
      • Jul 2007
      • 4171
      Service manual:
      http://www.eserviceinfo.com/download..._51SWX20B.html
      Covers your model.
      You will need WinRAR to put all the pieces together to make the PDF file.
      veritas odium parit
      • grungerokker13
        • Nov 2009
        • 4
        Ok I downloaded the service manual so just give me a few hours to look through it and check the schematics and I'll get back. Thanks for the suggestions and thank you for your patience with a novice like me.
        • grungerokker13
          • Nov 2009
          • 4
          Ok I'm not seeing the filament tubes on the schematic are they located at the bottom of the crt's?
          • grungerokker13
            • Nov 2009
            • 4
            *bump*
            There are no lights coming out of the crt's at all.
            • vestaviascott
              Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
              by vestaviascott
              Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
              Here's what happens:
              1) Power on
              2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
              3) Blue status light flashes for appx 4 minutes...
              07-29-2020, 06:08 AM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • JackUzi
              HITACHI 55HK6T64U Picture ghosting and jumping
              by JackUzi
              First post so please bear with
              So I found a similar issue on another thread but have been advised to open a new one so here it is.
              One day this TV started doing this:
              https://www.youtube.com/watch?v=42QlTOSOCjw
              This happens on all inputs and menu screens.
              Thank you to nomoresonys for previous advice - to check voltage on powerboard connector and possible loose/bad tab bond.
              I've opened it up and tried reseating all the ribbon connections but the problem remains. I need some support in testing...
              11-23-2023, 06:47 AM
