Samsung UE48JU6400W - back light on, sound on, sometimes picture.
  • dronerat
    • Nov 2019
    • 29
    • Bulgaria
    Hi Guys,
    This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
    PSU: L48S6 FHS BN44-00807D
    T-Con: BN95-01937A
    Panel: CY-GJ048HGLVLH
    MB: NA (Currently as the TV is assembled and forgot to take picture)
    As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
    It was sent to an authorized service for repairs and returned with the diagnose that the LCD panel is dead.
    I took it, as I like to tinker with electronics and started troubleshooting it. Thought that i should give it a try by replacing the T-Con board.
    First the TV did not start, but after some tries picture came back and it was perfect. No artifacts or anything. TV seems to respond well to the remote, etc. I assembled it again and it was working for some time, but after powering it off from the remote and powering it back on the picture was gone again. After waiting for 5-10 minutes and then powering it back on the picture is back.
    What I have checked on the PSU:
    I have looked at the PSU board but did not find any visibly burnt components.
    I have measured the voltages on the test point on the transistors of the PSU. On the board it says that the Power on voltage should be 13V and it is present, but the standby voltage is 9V instead of 8V. Also there is a high pitched sound coming from the PSU when the TV is in standby mode.
    What I have checked on the T-Con:
    T-Con has two LEDs. When the TV is powered on one of the LEDs is constantly on, but the other one flashes for a second and then turns off. In the case where the panel works both LEDs are lit constantly.
    To sum everything up:
    1. Checked the PSU. Power on Voltage is 13V as expected, but standby voltage is 9V instead of 8. High pitched sound coming from the PSU board when in standby mode.
    2. Replaced the T-Con board. It has 2 LEDs which are constantly on when panel works fine. When the panel does not work fine one of them flashes for a second and goes off.
    Is it possible that these 9 volts during standby somehow mess with the TV so it does not really go into standby and mess the startup procedure of the TV?
    Since the panel works fine (when it works) I really start to doubt the diagnose from the repair service the TV was sent to.
    I am not really sure how to proceed further with the troubleshooting. Any help would really be appreciated.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung UE48JU6400W - back light on, sound on, sometimes picture.
    Have you tried to update it's firmware It may be worth trying.
    https://www.samsung.com/ie/support/m...E48JU6400WXXH/
    • dronerat
      • Nov 2019
      • 29
      • Bulgaria
      The panel stopped working again completely, and I am not able to bring it up again.
      I will try to manage and update the firmware blindly, but I am not sure if I will manage to get through the prompts. Or keep trying to start/restart the TV until the panel fires up again and then update it.
      I will later upload some pictures of the components if someone sees something that is not right.
      • dronerat
        • Nov 2019
        • 29
        • Bulgaria
        Here are pictures of the internals of the TV
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          What voltages do you have on connector CNM803
          Can you give the pin No., Pin Name, Voltage of each pin 1 - 12
          Pin 1 Fail Count = xxV
          Pin 2 ANA_DIM = xxV
          Pin 3 A13V = xxV
          etc
          What voltage do you have at the fuse on the Tcon
          What voltage do you have at the connector feeding the led strips
            • 12074
            • U.S.
            Maybe check your diodes on powerboard, meter in diode mode, should get a reading about .3xx to .7xx in one direction and OL or 1 when you reverse the leads.
            • dronerat
              • Nov 2019
              • 29
              • Bulgaria
              Checked the voltages in standby and powered on state:
              Standby:
              1. FAIL_COUNT - 3.15V
              2. ANA_DIM - 0V
              3. A13V - 9.01V
              4. OD_ON/OFF - 0V
              5. A13V - 9.02V
              6. PWM_BLU - 0V
              7. A13V - 9.02V
              8. POWER_ON - 0V
              9. A13V - 9.02V
              10. GND - 0V
              11. GND - 0V
              12. GND - 0V
              Fuse on T-Con - 0V
              Powered on:
              2. ANA_DIM - 3.38V
              3. A13V - 12.84V
              4. OD_ON/OFF - 3.33V
              5. A13V - 12.84V
              6. PWM_BLU - 3.29V
              7. A13V - 12.84V
              8. POWER_ON - 3.29V
              9. A13V - 12.84V
              10. GND - 0V
              11. GND - 0V
              12. GND - 0V
              Fuse on T-Con - 12.79V
              The regarding the power to the LED strips there are 4 wires:
              - 104V Black
              - 104V Black
              - 208V Black
              - 0V Grey
              I found three diodes on the board(except the one in the rectifier) all in all and they both measure fine.
              EDIT: All voltages are measured while the ground probe is connected to the LCD panel.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                I'm not sure of the Fail_Count but all the other voltages for "power on" appear to be OK including the backlight voltages. You have 12V on both sides of the fuse?
                So the backlights are working but no picture? Do you have sound?
                  • 12074
                  • U.S.
                  Maybe try disconnecting the wi-fi board, see if tv works.
                  • dronerat
                    • Nov 2019
                    • 29
                    • Bulgaria
                    12.79V on both sides of the fuse.
                    Yes. When I connect the coaxial cable channels are working and sound is coming out of the TV.
                    No success.
                    It seems that the T-Con is trying to start, because the second blue LED flashes for a second when powering on the TV, but then the LED turns off and picture is not coming up. When the panel was working yesterday both of the LEDs were on constantly.
                    Per some guide I found I have also tried disconnecting the ribbon cables to the panel in order to at least get half of screen working, but nothing comes up.
                    When I disconnect one of the ribbon cables from the T-Con to the panel(it doesn't matter which one) the second LED on the T-Con does not light up at all.
                    Is there any way I can make this particular T-Con/Panel display test patterns?
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      I'm not aware of how you can set up any display test pattern on the Tcon.
                      Can you replace the tcon. They appear to be inexpensive.
                      • dronerat
                        • Nov 2019
                        • 29
                        • Bulgaria
                        I have already tried replacing the T-Con with little success. I got it to fire up sometime after replacing the T-Con but shortly after that it stopped working again.
                        I did some more investigation. Replaced the thermal paste on the T-Con and went on for the motherboard to replace the paste as well. I saw some test points and decided to give them a try(Pictures attached).
                        The test points for the EEPROM are at 3.3V which i believe is good.
                        I have measured CVBS_OUT and it gives 0.89V and the 5V point gives 5.13V and all other give 0(IMG_1519.jpg). Not really sure if it is OK.
                        The thing that bothers me is the SPI set of test points (IMG_1519.jpg) on the motherboard.
                        The readings there are as follows:
                        SPI_CS - 0.46V
                        SPI_MISO - 2.43V
                        SPI_WP - 0V
                        SPI_MOSI - 0.82V
                        SPI_CLK - 1.30V
                        SPI_GND - 0V
                        SPI_VCC - 3.29V
                        Shouldn't SPI_MISO and SPI_MOSI both have the same voltage levels? As far as I have read (for SPI communication) they should be between 2.5V-5V. SPI_MISO seems around that, but SPI_MOSI is far from 2.5V.
                        I have disconnected the T-Con board and measured again, but the voltage levels are the same.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          If you think it may be an EEPROM problem try freezing it with a can of freezer spray and then power up.
                            • 12074
                            • U.S.
                            Wonder if they sent you a bad tcon, maybe test both for proper voltage, some have clearly marked test points, some not so clear.
                            • dronerat
                              • Nov 2019
                              • 29
                              • Bulgaria
                              Ok. I have put the old T-Con back. Left it unplugged overnight and somehow the TV Panel powered on again.
                              Both the LEDs on the T-Con are on now (picture attached).
                              I tried updating the firmware, but it says that there is no new version. As far as I read there is no way to downgrade the Firmware version to check if it is a Software issue.
                              I managed to enter the service menu and also took some screenshots.
                              I see one SMPS Fail detect in one of the diagnostic menus. This might be caused because I accidentally shorted one of the mosfets white taking measurements, but I have no way of knowing as I could not get into this menu before the accident.
                              Performed also some tests through the HW Test menu and the only abnormal thing I see is the HDMI Switch IC test that it lead to some strange picture being displayed. Currently I have all the eco features and auto power off disabled and it is playing Youtube videos just to see if it will turn off again while playing.
                              This TV is driving me nuts, but I still believe it is repairable.
                                • 12074
                                • U.S.
                                I think that confirms that they either sent you a bad tcon or you somehow got a incompatible tcon from them.
                                  • 12074
                                  • U.S.
                                  So you didn't see anything in the service menu that might relate to that fail_count? MUST be extra careful in service menu, it's not too hard to brick a tv from in there.
                                  • dronerat
                                    • Nov 2019
                                    • 29
                                    • Bulgaria
                                    I double checked the labels. There is only one difference which I believe has to do with the manufacturing date or something (Pxx marking on the T-Con). I mean that yesterday i put the old T-Con back after changing the thermal pastes and everything and it was behaving the same way with both T-Cons. Left the TV unplugged from the mains overnight and it turned back on. That is when it started normally.
                                    Since I needed to power it off from the remote to get to the service menu it powered on correct again. Had 2-3 power offs while looking through the service menu and one of them did not start correct, but the others did. Now I am afraid to power it off again as it may not power back on correctly.
                                    The only thing I see that might be related to the fail_count signal is this measurement (SMPS Fet Fail Detect 1 in file IMG_1530.jpg). If you have any other idea of what I can check in the service menu. Any diagnostics, etc. I will be more than happy to do so.
                                      • 12074
                                      • U.S.
                                      Maybe do a factory reset while you have it working.
                                        • 12074
                                        • U.S.
                                        Suppose it could be an intermittent eeprom issue??
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • slimsoul
                                          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                                          by slimsoul
                                          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                                          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                                          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                                          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                                          03-12-2024, 03:55 AM
                                        • marekk
                                          Samsung QE55Q67RAT no sound and bad picture when streaming
                                          by marekk
                                          I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                                          I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                                          Mainboard is based on pcb BN41-02695A BN94-14007B
                                          I will appreciate any help
                                          Many thanks
                                          Marek...
                                          05-29-2025, 02:23 AM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
