Slowly understanding and repairing aquos tv. just have a question
  • morgan
    • Nov 2009
    • 12
    So when a mostfet shorts out does it take a lot of other stuff with it?
    i have a sharp aquos lc-30hv4u and one of the n-channel 900v mostfets burned out. i've replaced the 2 mosfets (since i was in there i figured i'd replace both) and fuse so now i get a red light instead of insta popped fuse. The only problem is that when i turn the tv on with the onboard button or the remote the light turns green like it's going to click on but there's no satisfying relay click and the tv doesn't turn on.. if i click the relay myself it just blows a fuse.
    I'm thinking i'm dealing with a chain of destruction and not just one part.
    if anybody has any thought's they'd be greatly welcomed. (i've got the service manual and i understand about 30% of it but i'm learning)
    thank you.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Slowly understanding and repairing aquos tv. just have a question
    thank you.
    Depending on the application, yes, it could result in a trail of destruction. Does the Service Manual include a schematic?
    PlainBill
    • morgan
      • Nov 2009
      • 12
      it does include a schematic which i can read bits and pieces of.
      (not because it's bad quality but because i'm not very good at reading schematics)
      • morgan
        • Nov 2009
        • 12
        i thought i'd add the schematic for good measure.
        http://www.morganhocking.com/powerboard.png
        i highlighted the two mosfets i replaced. the q9 (the bottom of the two on the schematic) was the one that was shorted out.
        • PlainBill
          • Feb 2009
          • 7034
          This is a lot more complicated than I am used to. I haven't dug too far into it, but some things are apparent. Q5 and Q9 are the power FETS driving the transformers for the power supply. T1 and T2 are for the 10 volt supply, T3 and T4 are for the 13 volts supply. These are the main supply for the TV.
          The key appears to be the circuit at the bottom. IC2 and T6 make up the standby supply, with PC8 providing the feedback for regulation. What's the voltage at CN3, pin 3? The command to energize the relay comes from the main board on CN3 pin 7.
          PlainBill
          • ecking767
            • Oct 2009
            • 492
            I will start by checking out those biasing resistor: R27, R28,R31,& R32. Since there was a short sometime other components are effected. Also check the output voltage you should have +13 volts.
            • PlainBill
              • Feb 2009
              • 7034
              That may be a possibility
              ???? Not bloody likely!!!! Note the information below from his first post.
              Then check the schematic. The left side of D1 (the main bridge rectifier) doesn't get connected to the AC line until RL1B (the relay) closes. The standby supply is working; the main supply isn't even getting power.
              Morgan,
              Which fuse is blowing? It appears we also need the schematic of the operation board - I want to see what is happening to the AC in. And it appears the we have to see the schematic of the main board so we can get an idea of why it's not telling the relay to close.
              Also, note Wizards comments in this thread. (It's always a good idea to listen to Wizard).
              PlainBill
              • morgan
                • Nov 2009
                • 12
                Thanks for all the suggestions I'm going through and following them all to see if I can make any headway.
                • ecking767
                  • Oct 2009
                  • 492
                  I always confirm before and after replacing a faulty component(s) the problem was fix. If there isn't 13volts why short out the relay?? ?? do you have +13 volts??
                  • morgan
                    • Nov 2009
                    • 12
                    ???? Not bloody likely!!!! Note the information below from his first post. Then check the schematic. The left side of D1 (the main bridge rectifier) doesn't get connected to the AC line until RL1B (the relay) closes. The standby supply is working; the main supply isn't even getting power.
                    Morgan,
                    PlainBill
                    the f1 fuse is the one that's blowing and i would have been more than happy to replace the whole board if the board didn't cost 500 dollars (doesn't seem sensible for a tv from 2003).
                    i'll post the schematic for the main board this afternoon. after i prod around a bit.
                    • electroguy75
                      • Dec 2008
                      • 21
                      chk the bridge d1 and and surrounding components
                      • morgan
                        • Nov 2009
                        • 12
                        ok. so. heres the main board schematic.
                        http://www.morganhocking.com/mainunit.png
                        I pulled the bridge rectifier off and tested it with the dmm and it seems to be in order.. figuring out how to test stuff i don't know how to test has become one of the fun parts of this tv excursion.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          The last tiem I had to tackle something like this I used a Variac and an isolation transformer to increase the AC voltage slowly. Using a light bulb to limit current would also be a good idea.
                          As I see it, the best approach would be to isolate each section of the circuit. The problem I'm having is I'm unable to understand parts of the circuit. I THINK the circuit includig Q1, IC1, L3 is related to power factor correction.
                          Q5, Q6, PC2, T1, T2 and associated components form the 10 Volt regulator. Q9, Q10, PC4, T3, T4 and associated components form the 10 Volt regulator. IC2, T6, and PC8 and associated components form the stand by power supply. I guess Q13, Q14, Q22 and associated components are the high temperature shutdown circuit. Note the temperature rating for F9. But I'm clueless about what PC1 and PC6 do.
                          PlainBill
                          • ses4you
                            • Jun 2006
                            • 11
                            Anyone have a schematic for this TV. Thanks
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                            • jesterace
                              Samsung UE46ES8000 Blown fuse but no other signs of short
                              by jesterace
                              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                              09-11-2024, 03:14 PM
                            • jshhh
                              Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                              by jshhh
                              Hi guys,
                              I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                              How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                              Anybody know how to remove this type of fuse?
                              (The fuse is toward the bottom of the image labeled F2)...
                              06-17-2025, 01:35 AM
                            • Babbar
                              by Babbar
                              04-12-2024, 01:12 AM
                              Surface Mount Fuses Fundamentals Datasheet
                              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                              10-07-2024, 06:07 AM
