Hisense 50k680 no power no standby
  • EUWest
    • May 2019
    • 44
    Hi folks!
    Just got an Hisense 50k680 with no power and no standby. I dont get any dcv (ether 16dcv or 5dcv) to mainboard. Did some basic checks on diods and seems like there find.
    On large caps C822 and C284 i get 315dcv. Is there a probleme on the cold side?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Hisense 50k680 no power no standby
    The problem looks like it's on the HOT (Live) side.
    If you have no +12V then check the components around N851 (8 pin IC) and also V871. Dont lose the ferrite bead on the leg of V871.
    • EUWest
      • May 2019
      • 44
      Tested V871 in circuit and seems like its fine. Do i have to solder it out and then test?
      And cant finde N851. In schematic its listed but on Board cant see it
      Edit//
      Lol forgot to Look on backside. Will do some testings now
      • EUWest
        • May 2019
        • 44
        Checked smd resistors nearby and get following results: in bracket will be value from schematic
        R901 506k (1k)
        R902 507k (1k)
        R903 270k (1k)
        R908 47 (27)
        R909 75 (47)
        R910 2k (2k)
        R911 9.6k (10k)
        R879 0 (0)
        R963 0 (1k)
        R964 1 (1k)
        R881 0 (0)
        Because there are many resistors differ from schematic value, is there problem somewhere Else or are smd resistors died?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          What are the numbers on each of the resistors. Better still a photo of the underside of the board.
          It is quite possible that the component values have changed and is dependant on the board revision.
          • EUWest
            • May 2019
            • 44
            attached photo
              • 12323
              • U.S.
              Resistor value: https://www.hobby-hour.com/electroni...calculator.php
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                They all apear fine and match your circuit except for R964 which you say is 1K and the board shows as 0 ohms. Double check and also check the zener diode VZ901 and transistor V901
                Edit
                Just re-read your results and R964 is down as 1 which I suspect you meant 1 ohm which is fine.
                • EUWest
                  • May 2019
                  • 44
                  R964 is about 1 ohm, not k ohm.
                  VZ901 is about 0.74 voltagedrop in diode Mode.
                  Found an theard where was similar Board with no power and standby. There was ic chip the problem.
                  https://www.badcaps.net/forum/showth...Hisense+55k610
                  Do i have to use chasis ground for testing Voltages from ic?
                  @nomoresonys thanks for your link, but didnt get how it could Help me
                    • 12323
                    • U.S.
                    Just put it up in case you had trouble knowing the value of resistors, couldn't tell exactly what your question was.
                    • EUWest
                      • May 2019
                      • 44
                      Got it! Thanks, will Bookmark it
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        No. Use the HOT ground which is the negative (-) leg of the 450V capacitor C822 (or of C824). Be careful the meter probe or clip you use does not slip.
                        • EUWest
                          • May 2019
                          • 44
                          Is it possible to Plug ac cord to Power supply without installing it in to the Chassis? Otherwise how can i test ic voltage? Its on the backside i forgot
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Disconnect the mainboard. Remove power supply and turn it over ensuring that it is well insulated from any possible metalwork that could cause a short circuit. Test with care.
                            • EUWest
                              • May 2019
                              • 44
                              Weile testing R906 Burned so i dont now if my results are right or not.
                              I get on
                              Pin 1 (Skip/latch) : 0.34V
                              Pin 2 (FB): 0.34V
                              Pin 3 (CS): 0V
                              Pin 4 (Ground)
                              Pin 5 (DRV): 0.01V
                              Pin 6 (Vcc): 15.7V
                              Pin 8 (HV): 265V
                              Could this be correct?
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                R906 (has 102 printed on it) looks like a 1K ohm resistor so if you measure it you can tell if it's OK or not.
                                So the iC Pin 6 VCC has 15 volts which is a little low since the circuit says 20V but should be good enough for it to run.
                                Pin 5 which should drive the mosfet is not doing so.
                                Pin 3 should be monitoring the current through the mosfet via R912 (which you can check is not open circuit)
                                You said the mosfet V871 was OK so I'm suspecting N851 and would look at replacing it.
                                • EUWest
                                  • May 2019
                                  • 44
                                  Which ic should i order? Are in schematic is NCP1271D65R2G Listed, on PS its 1271A PSAG.
                                  Online i found 1271D100R2G, should this okay?
                                  R906 has now 280 k ohm, have to Replace it too
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    The NCP1271D100R2G looks good. It's an 8 pin SOIC device so should match yours in size.
                                    • EUWest
                                      • May 2019
                                      • 44
                                      Just replaced NCP1271 but nothing changed. What else can it be?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Did you replace R906?
                                        Do you still have +15V on pin 6 of the NCP1271
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • LemoneyF
                                          Hisense 50r6- no standby, no power, bad main board?
                                          by LemoneyF
                                          Hi all
                                          I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                                          I have tested the power supply and found the following:
                                          363V and 373V across the input caps
                                          bri- 0V
                                          ana- 0V
                                          vamp-17.03V
                                          vamp-17.03V
                                          stb- 0V
                                          12V- 9.3V
                                          12V- 9.3V
                                          To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                                          10-12-2022, 07:44 AM
                                        • EUWest
                                          Hisense rsag7.820.5687 no power no standby light
                                          by EUWest
                                          Hi!
                                          I have a power supply and on the TV no standby and no power. Have already installed a replacement power supply but the same problem.
                                          When I test both power supplies the main capacitors while plugged in, I get 0v.
                                          What could be the reason for this?...
                                          04-14-2023, 08:59 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
