Samsung UE40D5000 , completely dead!
  • R_J
    • Jun 2012
    • 9625
    Re: Samsung UE40D5000 , completely dead!
    There is no point replacing RS807 unless you also replace ics801s. The standby is is shorted, that is what opened the resistor.
    Check the ic between pins 4,5 (Drain) and pin 3 (CS), It is likely shorted.
    • nomoresonys
      • 12331
      • U.S.
      Ok, wasn't clear if ICS801S was good or not so need to replace both, then give it a try.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Will do the test RJ.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          @RJ , is this the same resistor like in washingmachines? If SMPS fails the resistor fails also?
          Any idea how much ohm it should be? 35 maybe?
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Red prope on CS and black on drain reads +/-645.
              How do you get +/- 645 Ohms reading? Did you set the meter to Ohm mode to check the resistance?
                09-07-2024, 05:50 AM
              • max-power
                Dell E6540 laptop completely dead after dssasembly
                by max-power
                Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                03-24-2025, 08:49 AM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
