DVR HIKVISION DS-80237_p rev 5.0 BIOS Need
  • londy_9
    • Sep 2018
    • caracas
    I have a Hyundai with a ds-80237_p rev5.2 plate which has a mx25l12835f chip. I wanted to delete the password. I made a dump and saved it. I tried to write a dump that I got here but from a hikvision ds-80237_p rev5.2 and it always gives me an error. It says that the data recorded on the chip does not match the data in the file I am writing to it. The same thing happens if I try to put in the original dump that I read. The DVR no longer turns on and does not work. As additional information, I use a ch341a programmer and I see that the hikvision DVR uses a 25q128jvsq chip. I don't know how to solve it anymore.
    • yodaxxx
      • May 2012
      • Romania
      admin password >> what Pattern Z means here ?
      from numpads as 78952123 or what?
      thx
      • chilap
        • Mar 2015
        • 4
        • hcm
        Dear all , I need dump for DVR HIKVISION DS-80303_P REV 1.2 Model no : DS-7104HQHI-K1
      • param
        • Dec 2020
        • 9
        • india
        CP PLUS DVR MODEL NO : CP-UVR-0801E1-CS NEED BIOS
          SMDFlea commented
          Editing a comment
          Off topic.
      • Vytayant
        • Jun 2023
        • Kenya
        Originally posted by suveercomp
        Re: DVR HIKVISION DS-80237_p rev 5.0 BIOS Need
        Admin Password pliz
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          Today, 04:09 AM
