Vizeo E500i AO dead with led on
  • rayxoxo
    • May 2013
    • 34
    • usa
    #41
    Re: Vizeo E500i AO dead with led on
    R-J
    jp113 and 116 were measured from C120 neg. not chassis gnd.
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • chth96
      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
      by chth96
      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
      Since then, This AC/DC adaptor have been out of order.
      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
      And Is there any possibility that it will suddenly explode as well as to be out...
      12-03-2023, 04:40 AM
