arçelik A49L 5531 4B2 with sound image yo
  • necatduman
    • Feb 2015
    • 72
    • siirt
    model: arçelik a49l 5531 4b2
    PCX0000000 SN: 60500583
    SERINO: 99795605005836 MOTHERBOARD: ZSN190R-5
    there is no sound, there was no image, the led bar was defective, I changed it, but now the led bar is on, there is no image, t-con floor has 12volt. According to the customer, the TV was turning off when it was hot, everything is working on normal tv. When I remove the film, the screen is bluish nothing, I wonder if the panel is broken and I don't have a con card
  • necatduman
    • Feb 2015
    • 72
    • siirt
    Re: arçelik A49L 5531 4B2 with sound image yo
    t-con comes 12 volts led lights up again no picture
    • necatduman
      • Feb 2015
      • 72
      • siirt
      I changed the t-con, the TV is transferring another TV image from the same ATV scar.
      • necatduman
        • Feb 2015
        • 72
        • siirt
        Is there a possibility that the motherboard is broken?
        • necatduman
          • Feb 2015
          • 72
          • siirt
          this is the motherboard
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • domix
            Sony KD - 65XF9005 - No image, sound OK
            by domix
            at tv KD - 65XF9005 i have a problem.
            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
            is this a common problem for this tv?
            i attached pictures of inside. Supply board looks okey, no blowed caps....
            07-21-2025, 06:37 AM
          • Kartowl
            philips 47pfl6158k/12 image faded away, sound still coming from TV
            by Kartowl
            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
            04-23-2024, 12:57 AM
          • wolf1976
            samsung ue40d6100 has no backlight no sound and image
            by wolf1976
            hi to all
            on the above model of samsung i have the faults i have told already on the title
            iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
            any idea from someone what can i measure so i can find the problem ?
            the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
            11-17-2024, 01:02 PM
          • howardc64
            LG 43UK6500AUA no LCD image, backlight and sound okay
            by howardc64
            Similar to another LG UK series here
            https://www.badcaps.net/forum/showthread.php?t=93943
            Have backlight and sound. no LCD image.
            • main board has integrated T-Con
            • main board T-Con has LCD DCDC/PMIC RT6950GQW QFN68 package. Richtek chip. Can't find datasheet. Chip generates VADD (10.44V), VGH (~28V), VGL (~-14.5V)
            • RT6950 pin 18-19 (clockwise) appeared to be bridged. Unlikely from my probing, looks like ball squeezage so it probably got hot
            • Cleaned up bridging. Pin 17 is VGL (-14V) Pin 20 is VGH (28V). Pin 18 (I think 19 too) jumps between VGL and VGH voltage
            03-12-2023, 01:04 PM
