Philips 65OLED803 long time to clear residual image
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So, the tv is new, like bought 6 month a go...from time to time it asks to confirm that it can go to standby and clean residual image...sometimes i click later but most of the times when i go to sleep i confirm...and in the morning all is fine...
    But, yesterday afternoon it asked me again...but this time there was no later option...so i click ok (only option) and i forget about it...later that night i tried to power it on but it was saying that the clearing was not done all the way through...it will go to standby mode and restart cleaning process....so i was thinking ok...maybe i didnt gave it much time...but this morning same...i turn it on..and get message it is not finished and it will go to standby again and restart process..
    So, what is going on? I believe this process should last like 2 hours max...Any ideas? And one thing is interesting...that option "later" is gone...and when i turn it on i receive message it will restart (meaning start over again?)
    Any ideas?
  • Marszczak
    • Nov 2020
    • Poland
    Re: Philips 65OLED803 long time to clear residual image
    Did you manage to fix the problem?
    thx
    • Diah
      • Feb 2013
      • 6599
      thx
      hard reset from Factory/ service menu always the answer.
      • OscarAV
        HP Pavilion dm4-1065dx long time to get the power led on
        by OscarAV
        I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
        I have made a quick search for my laptop but I have not seen anything similar.
        I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
        09-23-2024, 05:53 PM
      • jagg
        Laptop MSI-16k5 Board model MS-16k51 V1.1 takes a long time to send video
        by jagg
        Hello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
        Here are the bios and the schematics.
        Could someone help me verify that the bios is correct? thank you so much !!...
        11-22-2023, 03:36 PM
      • sew333
        Light bulb flicker when turning on after long time off.
        by sew333
        Hello. I have question. I dont know if i have faulty wiring,bad installation or its bulb. When i have lights off long time and turn on lightning ( bulb halogen ) , there is a for 2-3 second bulb dimm/flicker and its normal. Happens only when lightning is off long time and i turn on.
        When i turn off lights and turn on again its fine. That flicker/dimm happens only when lights are off long time.
        That happens for example if i have lights off 2-3 hours and turn on.
        Thx
        02-16-2021, 01:39 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • crozoki
        Philips 65PUS6554/12 one time backlight flash
        by crozoki
        Hello
        I have Philips 65" TV (65PUS6554/12).
        Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
        Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
        Power board TPV 715G9187-P01-008-001S
        Main Board 715G9907-M01-B03-005K...
        09-03-2022, 05:47 AM
