Vizio m50-c1
  • Skavenger
    • Mar 2020
    • Use
    Vizio m50-c1
    I have a vizio m50-c1 tv... when I got it an turned it on it had a Purple tent to it... so looking it up lead me hear where I found a post with the same problem...
    So I opened the tv up... every thing looks good nothing I can see is burnt so that post lead me to the t-con an unplugging one of the Display wires... an that worked I got half the tv to work... I can see load up an Menu... was asking if I should buy a new t-con an see if that fixes it or do you think the tv panel is fired??
  • budwich
    • Jul 2015
    • 3097
    Re: Vizio m50-c1
    the key is what happens when you unplug the opposite side one (ie reverse the test)? Its probably not a tcon problem.... BUT the panel can be saved depending on what the real problem is with the panel.
    • Skavenger
      • Mar 2020
      • Use
      Re: Vizio m50-c1
      You dont get a picture it looks black kinda purple an when you hit the menu button you can see shadows where the menu would be... it does the same thing as if both are plugged it
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • Fly_Among_Stars
        VIZIO E70-E3 Half picture with half TCON
        by Fly_Among_Stars
        I have a VIZIO E70-E3.
        Symptoms: Black screen, no picture, but LED backlights are working.
        I probed the power board and voltages are as listed on the board.
        Main board appears fine, too.
        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
        There are two separate ribbon cables feeding the LCD.
        If both are connected, the screen is black.
        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
        04-24-2023, 08:20 PM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • tusiime
        How to access Vizio m652i-b2 service menu
        by tusiime
        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
        09-15-2023, 09:57 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
