Samsung UE46D6500 doesn't turn on and clicks
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung UE46D6500 doesn't turn on and clicks
    Did you check the voltage regulators on mainboard, he's checking them in video in post #11.
    • voxahbc
      • Mar 2020
      • 10
      • Turkey
      Originally posted by budm
      The diode D9601 tested bad in the circuit because it is connected in parallel with LOW Ohms resistor R960, you can look at the bottom side of the board to see how the Diode and the resistor are connected together.
      Samsung BN44-00427A
      https://www.shopjimmy.com/samsung-bn...pply-unit.htm#
      BTW, we never get to see what Voltages you have (you power up just the power supply board) on the power supply connector when the connector from the power supply NOT connected to the main board.
      Well actually I shared the results on the post #4. Am I getting it wrong? Just power cable connected while motherboard cable disconnected. I got only power and a5v constant, all the others are fluctuating.
      I checked. When all the cables connected and in stand by, I got zero volts, only constant voltages on the cable that goes to remote control receiver and panel buttons. When powered on, I got fluctuating voltage on regulators.
      • nomoresonys
        • 12331
        • U.S.
        Well I don't know what's wrong but I'll be watching this thread, hope someone can solve it.
          OK,I re-read your post #4 again and see that you did report the Voltages on the power supply connector without anything connected to it except the AC input to the board.
          Post #4:
          1 OD_LEVEL 5.3V Max - fluctuating
          3 OD_ON/OFF 5V Max - fluctuating
          5 GND Continuity checked - OK
          7 B13V 12.8V - fluctuating
          9 B13V 12.8V- fluctuating
          11 Vamp 12.5V - fluctuating
          13 Vamp 12.9 V - fluctuating
          15 GND Continuity checked - OK
          17 B5V 5.4V - fluctuating
          19 B5V 5.4V - fluctuating
          2 P_DIM4 0V
          4 P_DIM3 0V
          6 P_DIM2 0V
          8 P_DIM1 0V
          10 B13V 12.8V- fluctuating
          12 BLU 4.8V - fluctuating
          14 GND Continuity checked - OK
          16 GND Continuity checked - OK
          18 A5V 5.4V - constant
          20 POWER 3.4V - constant
          So the standby is steady, the PS-ON is steady but other switched supplied are fluctuating. The strange part is that the BL-ON is fluctuating too which does not make sense because the pull-up resistor between BL-ON pin is connected to the standby power supply output which is steady.
          • nomoresonys
            • 12331
            • U.S.
            Inspect powerboard for any cold/cracked/loose solder joints, look closely at components on heatsinks and transformer joints as they take the most abuse, could be a bad capacitor??
            • kacper69
              • Dec 2006
              • 18
              #26
              "When push to button to turn on "Smart TV" logo shows up and turns off with an endless cycle."
              I suppose the NAND memory has a problem.
              1. You can "freeze" this chip ( IC1301) on 10 sec.
              2. switch ON TV in service mode (INFO - MENU - MUTE - POWER )
              3. do FACTORY RESET in service mode.
              Sometime you need this operation 2-3 times.
              And TV could be work OK.
              In this way i rescue some Samsung TV.
              • nomoresonys
                • 12331
                • U.S.
                #27
                Any update voxahbc?
                • kacper69
                  • Dec 2006
                  • 18
                  #28
                  This operation is without any update.
                  But TV set is like new, need setting everything in operator mode.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #29
                    Damn dude that waving hand is irritating.
                    • voxahbc
                      • Mar 2020
                      • 10
                      • Turkey
                      #30
                      Any update voxahbc?
                      Unfortunately no any update. I might try with another powerboard if I find one.
                      • voxahbc
                        • Mar 2020
                        • 10
                        • Turkey
                        #31
                        Why do you think that it's motherboard so the NAND? While motherboard cable disconnected the voltages on the power board already fluctuate except power on and stand by.
                        • nomoresonys
                          • 12331
                          • U.S.
                          #32
                          I would still lift a leg on that diode and retest, just to be sure.
                          • bigstuff77
                            • Jun 2014
                            I've got a similar issue with similar readings on a UN46D6420. I'll be following this thread closely. Good luck.
                            • bigstuff77
                              • Jun 2014
                              I guess voxahbc gave up on this one? Is this problem fixable? I'm about to give up on mine.
                              • bigstuff77
                                • Jun 2014
                                I changed the LED strips on mine and now it works.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4542
                                  • Italy - Milan
                                  #36
                                  The problem is much common and is due to software conflicts. I ask to "shaking hand" which is the technical meaning of your guide? Can you explain? I see no sense in it.. For the fluctuating voltages i see that your tester has a BL icon that probably say its battery is low, so retest..
                                    09-07-2024, 05:50 AM
                                    09-06-2024, 11:40 PM
                                    09-06-2024, 08:40 PM
                                    Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                    This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-06-2024, 06:20 PM
