bn44-00214a no 12 and 24 voltages
  • anna1980
    • Mar 2016
    • 40
    • holland
    At this moment Im trying to fix this power supply.
    Problem is
    When I power on the tv the tv the red light appears. It sometimes responses to the remote, sometimes a couple of blinks but thats al
    The power supply is a bn44-00213a from which I downloaded the schematics
    When searching on this forum I checked a couple of thing.
    * I checked all the soldering joints and some of them I touched up a bit
    * I did the blowdryer test to check of the capacitors might be the problem. But I didn't expect them to be bad anyways. But that all didnt help
    * When not connecting pin 1 and pin 3 of cnm802 a get a steady 5.26v. No more voltages on the rest of the pins. The Bridge rectifier shows 230ac in and 310vdc out. So the main cap.
    * when connecting pin 1 and 3 the voltages on the connections jumps from 5.26 up and down from 3 - 3.3 volts. Maincap is still 310 volts
    Something I did see was some black (looks like burned) near CX802S, NT811 and CY802S and CY801S.
    The thermistor is a 5d-15 with a resistance of about 7 ohms. I think a bit high but it went down a soon a the soldering iron came near it.
    Somebody got any hints
  • R_J
    • 9557
    Re: bn44-00214a no 12 and 24 voltages
    Check the voltage ACROSS CB802, CB806, and CP811, these are in the primary and use hot ground, so it is easier to check the voltage across them.
    It could be that these caps are bad causing the vcc voltage to drop when the rest of the power supply tries to start up
    • anna1980
      • Mar 2016
      • 40
      • holland
      Hi
      Just checked them
      not connected pin 1 and pin 3 of cnm802
      cb802 -> 10.7
      cb806 -> 26.6 v
      cp811 - > 0
      connected
      cb802 > jumping from 12-14
      cb806 > jumping form 0.6 to 1
      cp811 > not really any voltage
      • Unspun01
        • Jun 2011
        • 349
        The NTC thermistor 5D-15 is an inrush current limiting NTC. Measuring 7 ohms is not too bad. Nominally, the specs say it is 5 ohms with 15mm diameter. Resistance should drop as the device warms up.
        There should not be black marks on adjacent components as seen in your photos. This suggests it may have experienced a surge or something.
        When plugged in, what is the voltage you measure across the pins of the large capacitor with the red dot on it?
        One thing I would do is gently scrape away that brown/yellow adhesive on the front of the circuit board. That junk is known to become conductive as it ages and cause power board issues. There are several spots in your photo that has it. GET RID OF IT. scrape it with a pick or whatever so that it does not bridge any electrical connections. With that adhesive scraped off, try re-connecting the board and testing again.
        • anna1980
          • Mar 2016
          • 40
          • holland
          Maincap is 310 volts. I am going to double check it tomorrow
          its 310volts in standby AND 310 when pin 1 and 3 on cnm802 are connected
          • R_J
            • 9557
            Originally posted by anna1980
            Hi
            Just checked them
            cb802 -> 10.7
            cb806 -> 26.6 v
            cp811 - > 0
            connected
            In standby CB806 is about right, but when you turn it on something is killing it, either the CB806 is bad (open) or there is something shorted on the m_vcc line after QB802. Check QB802 emitter to hot ground, there might be a shorted component like icp801s, or ICM801
            Try replacing CB806 first.
            • anna1980
              • Mar 2016
              • 40
              • holland
              Just to conclude my topic. Thanks to r_J. This weekend I finally got the tv repaired. I changed cb806 but no joy. But I had the ICP801S for just in case. And that was it. It's now up and running.
              Thank you all
              • Capacitorial
                Powersupply has all the voltages - Monitor still no power
                by Capacitorial
                Hello guys,
                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                The weird thing is, that the Power LED is powered over the TCON board.
                On The TCON...
                12-28-2024, 02:12 PM
              • gjgib
                Help reading schematic voltages input/output
                by gjgib
                Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                05-06-2024, 08:11 PM
              • RossMoodley1967
                HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                by RossMoodley1967
                Hello
                Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                03-01-2024, 06:07 AM
              • karlp028
                MSI Z390-A PRO missing VCORE voltages
                by karlp028
                I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                06-23-2025, 01:25 AM
              • lol999
                Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                by lol999
                Motherboard after starting show Q code 00.
                No shorts on any rail ( at last I can't finde any)
                All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                Nothing get hot, PSU starting, all lights came ON....
                One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                01-21-2024, 02:25 PM
