Samsung UN55MU6500 Turns on and off intially
  • Hy4woj
    • Oct 2017
    • 41
    Hey guys,
    Just picked up a free Samsung UN55MU6500 today. When you first turn the unit on it turns on and off by itself. It goes into this loop for a few minutes then stays on. I thought firmware, i tried updating it online, it says it has the latest firmware. When I initially turn it on, the panel appears to show a tab failure that the older Samsung panels were notorious for. The bottom portion of the screen is dark and appears delayed. So I'm thinking a panel problem? Anyone else familiar with this problem?
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
    09-07-2024, 05:50 AM
  • Robby-Gr
    TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
    by Robby-Gr
    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
    Additional issues:...
    09-27-2025, 12:02 AM
  • GeckoGreen
    Samsung service bulletin: need firmware file for PN63C550 TV
    by GeckoGreen
    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
    Will you please help me get the [2D63]LOGIC.bin file for my TV?
    05-17-2025, 02:47 PM
  • Egidio85
    Samsung UE55F8000SZ Turns on and off immediately
    by Egidio85
    good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
    This defect happens continuously, hearing the classic click of the relay every time.
    Power supply board BN44-00636B
    disconnecting the mains and lamps from the power board always causes the same problem.
    Is it normal that without anything connected this power supply turns on and off cyclically?
    any suggestions on what to check?
    thanks in advance
    03-11-2025, 12:45 PM
