[Vizio M60-D1] stuck at logo and rebooting. Serial dump is attached. NNo ENV device f
  • oscarchentwn
    • Nov 2019
    • 5
    • Williamson
    Hi There,
    Does anyone know what part is broken? Is that the kernel image (mmc) broken?
    Here is the serial dump from UART.
    Start Soc Driver load
    160+0 records in
    160+0 records out
    160 bytes transferred in 0.002 secs (80000 bytes/sec)
    This is NOT 2UMAC DDR 088 board.
    This is 2.5G DDR board, can support EDR.
    This board can support HDR.
    mipsflag in uBoot is same: 0x80000005
    This is SX7+FRCX board.
    Load 2.5G Driver setting
    [ 3.247647] PLF-CPU[914]: (File:/common/hudson_slaves/sith/workspace/P111_TV103_Sprint6_SX7A_Build/DCP_SYS/HAL_SX6/Kernel_Driver/cpu_comm/cpu_comm.c Line:1613 Routine:cpu_comm_init) - smp axi bus cpu_comm_init() - Enter. PhyMemAddr=ea00000, ShMemAddrBase=0, ShMemSize=23068672
    [ 3.272941] phy:0x1001404c
    [ 3.276818] phy:0x10014034
    [ 3.279544] phy:0x10014038
    [ 3.282246] phy:0x100140e0
    [ 3.284945] phy:0x100140e4
    [ 3.287642] phy:0x10014044
    [ 3.290422] phy:0x10014048
    [ 3.293123] phy:0x100140f0
    [ 3.295821] phy:0x100140f4
    [ 3.298909] PLF-CPU[914]: (File:/common/hudson_slaves/sith/workspace/P111_TV103_Sprint6_SX7A_Build/DCP_SYS/HAL_SX6/Kernel_Driver/cpu_comm/comm_request.c Line:943 Routine:InitCommMem) - ShMemAddrBase:cd000000, ShMemSize:1600000, pComm->pSharMem:cd0298b0, size:15d674f, ShMemAddr:ea00000, pAddr:cd0298b0
    [ 3.325782] PLF-CPU[914]: (File:/common/hudson_slaves/sith/workspace/P111_TV103_Sprint6_SX7A_Build/DCP_SYS/HAL_SX6/Kernel_Driver/cpu_comm/trid_smm.c Line:739 Routine:Trid_SMM_Init) - Add heap:0ea2a000, pWholeBlock:cd0298b0, size:15d674f, heapAddr:0ea2a000
    [ 3.368484] ************svp_init: Kmalloc size: ge2ddev: 216
    [ 3.374140] <1> hidtvPro_check_chip_type, data_word 9700
    [ 3.379460] ge2d: HiDTVPRO_SX7 chip found
    [ 3.383465] ge2d:====== svp var (xres 1920, yres 1080, primary size: 0xfd2000 linelength 7680)======
    [ 3.392591] ge2d:====== Allocate Memory for ge2d Driver from 0x29900000 to 0x338fefff ======
    [ 3.403179] ge2d.drv ge2d: init done Ver: 2.0
    [ 3.403358] ge2d.drv It successfully create GE2D DISP CHANNEL!
    [ 3.418294] <1> FBinit avail 0x9fff000
    [ 3.423052] ge2d.drv ge2d is ready now!
    [ 3.448913] Mali: Mali memory settings (dedicated: 0x0B700000@0x33900000)
    [ 3.477887] Mali: Mali device driver loaded
    [ 3.498152] PMan protection driver init, print_limits: 5000.
    [ 3.503845] <1> register PMan HUB0 IRQ (0).
    [ 3.508049] <1> register PMan HUB1 IRQ (0).
    [ 3.512238] <1> register PMan HUB1 IRQ (0).
    [ 3.532150] i2chtv_init enter pi2c_dev_class bf08e150
    [ 3.537674] i2chtv_init enter pi2c_dev_class bf08e244
    [ 3.543239] i2chtv_init enter pi2c_dev_class bf08e338
    [ 3.548706] i2chtv_init enter pi2c_dev_class bf08e42c
    [ 3.601297] [TRACE UNINITIALZED]: demux_module_init success
    [ 3.653671] karmorgate: armorgate_init
    [ 3.672941] hidtvreg: init done Ver: 2.0
    Finish Soc Driver load
    [ 3.703938] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: barrier=1
    [ 13.758045] mmc0: Timeout waiting for hardware interrupt.
    [ 13.767825] mmcblk0: error -110 transferring data, sector 994984, nr 32, cmd response 0x900, card status 0x900
    [ 13.777833] mmcblk0: retrying using single block read
    [ 13.786683]
    [ 13.786683] ==========pmandrv: Here comes PMan Hub interrupt (53).
    [ 13.794329] pman-hub: Group[18] Invalid Access Count:1
    [ 13.799458] pman-hub: BLOCKED_CMD 0xa700: (Data/Write cmd)
    [ 13.804933] pman-hub: BLOCKED_CMD_ID 0x7
    [ 13.808845] pman-hub: BLOCKED_CMD_BS 0x3
    [ 13.812759] pman-hub: BLOCKED_CMD_LINES 0x0
    [ 13.816931] pman-hub: BLOCKED_CMD_STRIDE 0x0
    [ 13.821190] pman-hub: BLOCKED_CMD_ADDR 0x987fd000
    [ 13.825883] pman-hub: BLOCKED_SEC_GROUP 0x12
    [ 13.830139] pman-hub: BLOCKED_REGION 0x8
    [ 13.834052] pman-hub: INT_STATUS 0x40000
    [ 13.837966] pman-hub: INT_ENABLE 0xffe7ffff
    [ 13.842143] pman-hub: (!)PMAN error for group[18: SDIO_1/2/SPI] tries to access address [0x987fd000] -- transaction volatile in region [3 ](-1 means default region), DDR[1]!
    [ 13.857583] pman-hub: (*)You can check regions from "/proc/pman_hub".
    [ 13.857583]
    [ 17.918115] No ENV device found!
    [ 17.921339] Enumerate ENV device failed!!
    [ 23.798021] mmc0: Timeout waiting for hardware interrupt.
    [ 23.805695] mmcblk0: error -110 transferring data, sector 995008, nr 8, cmd response 0x900, card status 0x0
    [ 23.815440] end_request: I/O error, dev mmcblk0, sector 995008
    [ 23.821808]
    [ 23.821808] ==========pmandrv: Here comes PMan Hub interrupt (53).
    [ 23.829453] pman-hub: Group[18] Invalid Access Count:2
    [ 23.834580] pman-hub: BLOCKED_CMD 0xa700: (Data/Write cmd)
    [ 23.840053] pman-hub: BLOCKED_CMD_ID 0x7
    [ 23.843965] pman-hub: BLOCKED_CMD_BS 0x3
    [ 23.847879] pman-hub: BLOCKED_CMD_LINES 0x0
    [ 23.852051] pman-hub: BLOCKED_CMD_STRIDE 0x0
    [ 23.856309] pman-hub: BLOCKED_CMD_ADDR 0x987fd200
    [ 23.861001] pman-hub: BLOCKED_SEC_GROUP 0x12
    [ 23.865261] pman-hub: BLOCKED_REGION 0x8
    [ 23.869174] pman-hub: INT_STATUS 0x40000
    [ 23.873088] pman-hub: INT_ENABLE 0xffe7ffff
    [ 23.877264] pman-hub: (!)PMAN error for group[18: SDIO_1/2/SPI] tries to access address [0x987fd200] -- transaction volatile in region [3 ](-1 means default region), DDR[1]!
    [ 23.892704] pman-hub: (*)You can check regions from "/proc/pman_hub".
    [ 23.892704]
    [ 33.838041] mmc0: Timeout waiting for hardware interrupt.
    [ 33.845697] mmcblk0: error -110 transferring data, sector 995009, nr 7, cmd response 0x900, card status 0x0
    [ 33.855440] end_request: I/O error, dev mmcblk0, sector 995009
  • oscarchentwn
    • Nov 2019
    • 5
    • Williamson
    Re: [Vizio M60-D1] stuck at logo and rebooting. Serial dump is attached. NNo ENV devi
    Before above step to get serial dump, I checked EEPROM, U202 which is able to be read/write. So EEPROM should be good and working.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8146
      try flashing the firmware.
      • Nick's Tvs
        • Jan 2014
        • 621
        Always worth a shot as well is to heat up the large BGA chips under the big heatsink with hot air and see if that allows the cycling to stop.
        We often see BGA issues with these boards.
        • oscarchentwn
          • Nov 2019
          • 5
          • Williamson
          I am still trying to figure out how to flash it. 9.0.5.2.utv is the current firmware what I download from Vizio website. I am not sure if I can just flash this file to or there is something I have to extract from *.utv.
          I haven't find information how to read or extract *.utv file.
          • oscarchentwn
            • Nov 2019
            • 5
            • Williamson
            Thanks for sharing. I can try this with heatgun.
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • mindoverflow
              ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
              by mindoverflow
              hello,
              there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
              I changed pads and thermal paste.
              I run mats test but it is reporting 0 errors.
              I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
              After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
              02-09-2022, 03:22 PM
            • plytek
              Samsung QE50Q60TA rebooting
              by plytek
              Hi all.
              I'm trying to fix my Samsung QE50Q60TA TV.
              IT's rebooting every few seconds.
              I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
              Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
              Can anyone suggest what I can test and do to get it working again please?...
              02-08-2025, 06:02 AM
            • unimatrix93
              SAMSUNG UE55TU7002KXXH rebooting
              by unimatrix93
              Hello everyone, I'm working on a Samsung TV that constantly rebooting.
              MB/PSU unit: BN9654185QE
              It loads up to the main menu then as soon as the backlight goes brighter it reboots.
              First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
              Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
              Also I have to note, that the MB/PSU combo gives out a very noticible...
              04-07-2025, 09:49 AM
            • BMCappelletti
              Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
              by BMCappelletti
              Hi everyone.
              Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
              Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
              Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
              02-18-2025, 12:22 PM
