Panasonic TC-P50U50 Mainboard Problem 14 Blinks
  • dcapper
    • Dec 2013
    • 496
    I was given a Panasonic TC-P50U50 with 14 blinks. I did all the checks on it and there was no shorts. I reset it holding the power button and tv fired right up. Here's the problem. The only input that is work is the antenna. The HMDI's or the component are not. If I try to scan channels it reboots. Could it just need a firmware update? Or is most likely the mainboard is fried? Also, could someone help me with the suffix please?
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Panasonic TC-P50U50 Mainboard Problem 14 Blinks
    I don't think a firmware update is going to remedy that problem. That board suffix is 'UA'.
    Shopjimmy shows a couple alternatives as compatible. UC and UG.
    https://www.shopjimmy.com/panasonic-...-tc-p50u50.htm
    • dcapper
      • Dec 2013
      • 496
      Thank you. I can understand the older shorting points for the suffix. But I have no clue how this one works. There's lots of these boards on eBay. I'll order one.
      • dcapper
        • Dec 2013
        • 496
        I ordered one from tv parts today. Got a sweet deal with 2 fedex shipping. Paid $49.01. I'll update once it's installed.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Good deal! Hoping for a positive update once you get it.
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
            11-20-2024, 08:52 PM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • Malva
            Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
            by Malva
            I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
            Mainboard model: EAX65684604
            PCB marking: EBT62954607
            SPI chip: Winbond W25X20CLNIG Problem description:
            Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
            After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
            • I bought another
            06-25-2025, 02:07 PM
          • hugocarmo
            Panasonic TX-24A1UN CRT Sound and Input problem.
            by hugocarmo
            Hi.
            I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
            It is imaculate inside, almost no dust or debris inside.
            The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
            So I started to look for a service manual, I found one, and started from the beginning.
            Most of the times the caps are the problem so I orderer all the caps for all boards,...
            04-26-2025, 07:45 PM
          • micsa84
            Mainboard problem Laptop Lenovo Ideapad 3 15ada05
            by micsa84
            Hello! I have a problem with a mainboard from a Lenovo Ideapad 3 15ada05.
            The problem is that the cooling fan is always on full speed, It doesn't recognize the battery and it is not charging it and the keyboard has only partial functionality, many of the keys don't work.
            I tried a new bios update but that didn't changed anything.
            What could be the problem with it?
            08-15-2023, 10:46 AM
