LG 42LE7500 TV Backlighting but no Picture
  • bwilliams60
    • Aug 2014
    • 109
    Good Evening All. I have a 42" LG TV that was given to me and my background is more automotive electronics so was hoping for some direction on this. I can get around the TV okay, just need pointing in the right direction. This TV starts up okay and backlighting comes on with no problem but there is absolutely no picture. I have ran an infrared monitor over the power supply and most areas that I think should get hot, are, but that is obviously no measure of anything so where should I start with this one?
    It has two boards in it. Mainboard and Power Supply I am assuming. I don't have any pictures yet but if you need them, I can upload some later on.
    Thank you in advance.
    • 12328
    • U.S.
    Re: LG 42LE7500 TV Backlighting but no Picture
    Yep, throw up some good straight on pictures of all the boards and one of the whole back and how they are connected, try test number 3 below.
    • bwilliams60
      • Aug 2014
      • 109
      Okay here are the voltages I got with Power Off and then Power On
      ON 0.00 VDC 3.25 VDC 20V 0.00 VDC 21.4 VDC
      20V 0.00 VDC 21.40 VDC 20V 0.00 VDC 21.4 VDC
      GND 0.00 VDC 0.00 VDC GND 0 0
      3.5V 3.48 VDC 3.40 VDC 3.5V 3.3 3.3
      GND 0.00 VDC 0.00 VDC V-SYNC 0 0
      12V 0.00 VDC 12.28 VDC DRV-ON 0 2.9
      12V 0.00 VDC 12.28 VDC SCLK 0 0
      12V 0.00 VDC 12.28 VDC PWR DIM 0 3.2
      SIN 0.00 VDC 0.02 VDC Error Out 0 0
      Pictures to follow momentarily
      • bwilliams60
        • Aug 2014
        • 109
        Here are my pics. I suspect that 20V circuit may be a problem?
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          The cpu chip is in need of a re-balling, or a quick reflow with a heat gun on low for about 45 seconds. Remove the big black heatsink, then heat it evenly.
          • bwilliams60
            • Aug 2014
            • 109
            Thank you @tvtimmy for your response. I have seen where people have heated their mainboards in an oven at 380 for ten minutes. What you are saying is to just heat the cpu? Is that the only part that is losing connection? I can do that with my hot air station. Any recommended temperature? I generally run my station at 225 for most things. Thoughts?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              Just heat up the chip under the black heatsink. A hot air station will work very well, only heat the chip . I put a towel under the board to prevent the surface mounted parts from falling off. Set the temp just over what it takes to melt leaded solder. Let it cool and try it out.
              • arbitarytwist
                • Nov 2016
                • 31
                Did this fix your issue?
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • CyberPhoenix
                  Issue with picture quality of Sony bravia TV
                  by CyberPhoenix
                  Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                  01-22-2024, 02:08 AM
                • Rauni
                  Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                  by Rauni
                  Hello, this is my first post on this forum, and my first attempted to repair a TV.
                  My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                  Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                  Read also that we should test what happens if we...
                  10-01-2023, 12:06 AM
