RCA LED60B55R120Q Shuts Down
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    This set shuts down on it's own after 10-15 min with rear cover on. Will run for days with rear cover off. If I cycle power, it will fire back up for another 10-15 min.
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: RCA LED60B55R120Q Shuts Down
    Upon further investigation, through using a heat gun and two different power supplies, I have localized the issue to the power supply. Sometimes only backlight driver section dies even though BL_ON is still getting signal from main board..audio continues, still have 12 volts..other times 12 volts drops out and kills everything. I still have 5 volts stdby when 12 volts dies.
    Both LED driver circuits read the same voltage to the tenth of a volt(157.1). Main Cap reads 306 volts when set is running.
      • 12322
      • U.S.
      Main cap is 306v and you have a good picture display or do you mean when it acts up?
      • R_J
        • 9627
        Check the power supply ON/OFF pin, The standby +5vsb, +5v, +12v come from the same power supply section, but the +5v & +12v are switched, so it seems they are being turned off when the fault happens. If the ON/OFF signal is lost this also turns off the pfc circuit dropping the main cap voltage from 305vdc to 160vdc
        I would also check the solder connections on the transformers and any of the transistors mounted on heatsinks.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Main Cap is 306 when working properly. I re soldered every power passing device and contact on the power supply, including all three transformers..Been running out in the shop for an hour with the back panel on and it's 75F here today..Before within 15 min it would turn off with back panel in place and it was 50F.
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Well I just lost back light driver section still have 2.5volt ON/OFF and 5 volt BL_ON signal as well as audio. All 5 volt and 12 volt voltage is still intact. I can even turn it off, then back on and regain audio. I have read these sets are bad about LEDs failing. Could bad LEDs be overloading the driver circuit causing the overheat condition?Is there a way to test them without exposing them? I can access them from the rear of this set without having to remove the LCD panel.
            • R_J
              • 9627
              You can have one or more led's shorted, this keeps the string intact but draws more current and the led driver goes into over current protection. or sometimes the led's go intermitint and open, they do get quite hot, and the driver goes into over voltage protection.
              There is no real way to check them without exposing them, even a led tester might show them as good as they are intermitint.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                It must be going into over current protection as you say. I left it with 120 volts applied and let it get stone cold. Turned back on and still no back light driver. If I remove 120 volts for 15 sec and restart, back light comes back. Cycling power is resetting protection circuit.
                I will be exposing LEDs next. Thanks RJ!
                • neilc6
                  • Nov 2015
                  • 1550
                  RCAs have high rates of backlight failures because the default setting in Standard picture mode sets them to 100%. The backlight level can only be changed in the service menu under Panel Settings. menu-1-1-4-7 or source-2-5-8-0. Depending on the model, the backlight level will apply only to the currently selected input or be saved under User picture mode.
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    I will change the setting once I replace the arrays.
                    Thank You for the tip!!
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      Replaced LED arrays. Entered the Service menu via menu1147. Backlight was set to a default of 0. I adjusted it to a level of 4. I read in another bulletin that lower number = brighter setting. Could not find a setting that says "backlight level normal" in the service menu. Set worked for 4 hrs without losing backlight.
                      • Tony182
                        PlayStation 3 Super Slim (CECH-4004A) powers on for a brief moment and immediately shuts down. But works without cover..
                        by Tony182
                        Hello everyone, I received a PS3 console with the issue described in the title. I gradually measured the console (both the PSU and the motherboard) but couldn’t find anything—everything seems fine.
                        I planned to remove the casing and test whether the voltages appear on the coils, but after rewiring and turning the console on without the casing, the system actually booted, which blew my mind (it’s been seven days that I’ve been dealing with this). The processor started heating up, so I quickly turned the console off and tried reinstalling the heatsinks and turning it on again....
                        11-22-2025, 01:47 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • huzo
                        HP Omen shuts down when loading OS
                        by huzo
                        The model is 15ec-1061nm
                        Board number is DAG3EDMB8D0​
                        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                        10-29-2024, 12:05 AM
                      • Giggle2562
                        Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                        by Giggle2562
                        I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                        The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                        Here's what I've tried so far:
                        • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                        • The laptop shows an image on the internal display for a few seconds before it shuts down.
                        • I tried swapping the LCD panel with a known good one.
                        • I tried swapping the LCD cable
                        11-06-2025, 12:36 PM
                      • riko 656
                        Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                        by riko 656
                        I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                        Laptop Model:
                        • Model: Lenovo Legion Slim 5 16APH8
                        • GPU: NVIDIA GeForce RTX 4070
                        • Main BIOS chip size: 32MB
                        • VBIOS chip size: 16MB
                        Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                        What I Have Tried So Far:
                        1. I
                        11-04-2025, 05:14 AM
