Sony KDL-47V5100
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Sony KDL-47V5100
    Ok, didn't see post 8, what do you get if you have cable from powerboard to mainboard unhooked and plug ac into powerboard? Did you try the update with a different thumb drive? before anyone says it's a sony not a samsung, just don't.
    I will try both of those this afternoon.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      If I unplug the power to the mainboard, the lcd backlights don’t come on at all.
      I tried a different flash drive with the firmware update. The led on the flash drive flashes for a bit as if it’s being read but since there is nothing on screen, I can’t follow the prompts to update it
        • 12206
        • U.S.
        Read the install instructions on the link to sony site, you must follow install instructions exactly as stated, it's a self install no interaction required.
          • 12206
          • U.S.
          If I recall it will blink with 2 colors during update then change color and stop blinking when/if install is done and successful then turn tv off and unplug thumb drive might take 15 minutes.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            I saw that. I left the usb stick on for about 10 minutes and power cycled it.
            Now the front red standby led is off and so is the pic off/timer led.
            Now I have a green power led lit up but still no picture. Also the backlights stay on indefinitely.
            Still no response from the side buttons.
              • 12206
              • U.S.
              #26
              I had the solid green light and the update worked, been fine ever since, maybe try it again since you have the green light now.
                • 12206
                • U.S.
                #27
                Maybe check your voltages on powerboard connector again, see if anything changed.
                  • 12206
                  • U.S.
                  #28
                  Try the unhook cable from powerboard to mainboard again, plug ac into powerboard, see if it's different now.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #29
                    I’ve tried everything suggested. Now it sometimes turns on and off using a Sony universal remote I had and by the side buttons. Sometimes it doesn’t.
                    Sometimes it turns on and the backlights stay on, if I plug the coaxial cable or an hdmi from my roku in, it starts cycling the backlights every 10 seconds. Sometimes it doesn’t.
                    I give up. A new mainboard on eBay is more than I can get for the tv.
                    Also
                    The mainboard that is in it has a different number than on shopjimmy. On shopjimmy it ends in -11. Mine ends in -13.
                      • 12206
                      • U.S.
                      #30
                      Does it turn on enough to do a factory reset?
                        • 12206
                        • U.S.
                        #31
                        What is the panel sticker numbers?
                          • 12206
                          • U.S.
                          #32
                          You may be on to something, someone might have put the wrong board in there, not sure if 11 and 13 will interchange.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #33
                            Nothing ever shows on the screen. I can't do a factory reset.
                              • 12206
                              • U.S.
                              #34
                              What is the panel sticker numbers? And service code on back cover and first 8 letters of serial number?
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #35
                                The panel sticker is in my previous post. That's all I could find.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4338
                                  • Italy - Milan
                                  #36
                                  that is what i thought since the first posts, someone tried replacing mainboard with a different version, if you get a cheap programmer and first find a dump of the serial eprom for the correct model on the web you can put it in and you'll probably end with a perfect working set.
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    #37
                                    Way above my pay grade.
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      #38
                                      Mainboard number.
                                        • 12206
                                        • U.S.
                                        #39
                                        This worked for some but who knows:
                                        I've had this problem twice. Here's how I solved it. Turn TV on, as soon as BRAVIA goes off the screen, count a second or two and then quickly change channel. Up or down doesn't matter. Don't just do it once either to be sure press channel up or down multiple times. Timing is key. I don't have cable so this happened to me while surfing through the digital channels. I came across a channel that showed on screen for a second and then this problem happened. Anyways , good luck!
                                        • Malachi
                                          • Dec 2015
                                          • 1077
                                          • Usa
                                          #40
                                          Nothing ever comes on the screen.
                                          • Watson306
                                            6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                            by Watson306
                                            I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                            I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                            I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                            Many Thanks in advance.
                                            11-01-2022, 05:33 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • ptcriserx3
                                            Sony trinitron crt bowed and side color issues
                                            by ptcriserx3
                                            Hi
                                            Ive got a vintage 2001 sony trinitron flat tube tv
                                            The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                            See many images attached...
                                            Just windering if this is not fixable or something i can correct without getting too invloved
                                            Im trying to sell the tv
                                            06-17-2023, 07:27 PM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
