Panasonic TX-P50U30B Standby Problem
  • beechcraft100
    • Jan 2020
    Gents,
    Need a little help. Have Panasonic TX-P50U30B that is stuck in standby with red light on. No blinks. Switch on relay clicks but light stays red, Flickers if i use remote
    However set will not start. Relays click once, after 40 seconds one long click or relays then 3 short clicks, this is repeating every 40 seconds so its trying to start Standby is at 4.95v on pin 6 of P6 on power supply sending 5 v to the A board Beyond that have 3.5v on pin 7 which i assume drives the lamp.
    Tried the usual resets but nothing fault is same. Unsure if PSU board or A Board
    Screen is blank no sound
    Any help would be great or how standby works?
    Thanks in advance
  • beechcraft100
    • Jan 2020
    Re: Panasonic TX-P50U30B Standby Problem
    Me again Gents
    I have now fixed it. Here is how it was done.
    All usual ways with power button pressed, Power button pressed and channel up held etc none of this worked
    Solution was a reset with the remote. Hold down Standby button then press on the power button on TV. Dont release standby button until TV starts. Once started switch off with remote to standby then start again using standby button all is now well
    Regards
    Andy
