Samsung 55H6203FXFA won't power up
  • tikalize
    • Jan 2020
    • 16
    • U.S.A.
    I stated testing this unit and I had no backlights but I can see a picture with a flashlight to the screen. I started testing voltages at the 10 pin connector on the Power supply board (BN44-00774a) where the main board harness plugs in but and I accidentally touch 2 pins together (I believe it was pins 7 (13volts) and pin 9 (ground) Now I have no picture and no led on t con board. The red standby light come on and I can see the optical red light also illuminate. The backlights were shorted and was my original problem but now I cause this problem.
    Voltage is as follows on these pins:
    (1) 12.8v (13v)
    (2) 2.33v (od/us
    (3) 12.8v (13v)
    (4) 3.29v (blu/pwm)
    (5) 12.8v (13v)
    (6) 4.49v (ps/on)
    (7) 12.8v (13v)
    (8) ground
    (9) ground
    (10) ground
    Voltage @ cm863
    11.9v (standby) voltage drops to 10 or so volts when main board plugged in (load)
    12.8v (on) voltage tropes to 11 or so volts (load)
    Voltage @ cnl 802 (output to backlights)
    320v to 280v with main board unplugged
    280v and drops with main board plugged in
    Ps/on voltage drops from 4.49v to under 1v with power on and 4.49v in standby
    The backlights were unplugged during these voltage readings because I know I have to repair them due to being shorted.
    My question is does it sound like the main board was damaged when the pins were shorted during testing or maybe the Power supply got damaged? Before I go throwing parts at this tv I would like to see if there is anymore testing that can be done to be sure. I am not a tv repair guy but I do have electrical background in other areas. Please excuse me if I am not asking the correct questions or not testing what I should be. Any help to push me in the right direction would be greatly appreciated. Thanks.
    • 12192
    • U.S.
    Re: Samsung 55H6203FXFA won't power up
    Throw up some good clear straight on pictures of all the individual boards and one of the whole back to see how they are connected.
      • 12192
      • U.S.
      Recheck the model number.
      • tikalize
        • Jan 2020
        • 16
        • U.S.A.
        Sorry its UN55H6203AF.
          • 12192
          • U.S.
          Maybe test those voltage regulators on mainboard, good video there: https://www.youtube.com/watch?v=ocqnqmBxiqY
            • 12192
            • U.S.
            May have blown the tcon fuse, check if you have about 12 volts on each side of tcon fuse, black - probe on chassis ground red + probe on each side of fuse.
            • tikalize
              • Jan 2020
              • 16
              • U.S.A.
              tcon fuse has no voltage to either side and has continuity. (not blown)
                Post #1
                (1) 12.8v (13v)
                (2) 2.33v (od/us
                (3) 12.8v (13v)
                (4) 3.29v (blu/pwm)
                (5) 12.8v (13v)
                (6) 4.49v (ps/on)
                (7) 12.8v (13v)
                (8) ground
                (9) ground
                (10) ground
                Are those the Voltage readings at connector CNM803 WITHOUT connection to the main board? Are these what you are getting right now?
                Post #1:
                Voltage @ cm863
                The Voltage should be around 8V (PS-ON has to be grounded to put power supply board into standby mode due to the fact that the power supply board has Pull up resistors to simulate PS-ON signal when it is not connected to the main board. When main board is connected to the power supply board, the PS-ON will be kept low when TV is in standby mode by the main board, and it will go high when TV is turned on).
                • tikalize
                  • Jan 2020
                  • 16
                  • U.S.A.
                  I have seen the you tube video you have posted above. Maybe iam missing something but the main board i have dont have those IC regulator chips mentioned to test on this board. i have tried to find a service manual all over the internet. If i know what the voltages should be and where then i have a place to start. All the voltages match without the main board plugged in that of other posters with the same power supply but for some reason it seems like when the main board is hooked up it looks to me like there is an excessive load. Iam leaning on a defective main board but iam not a parts changer. In my field you dont change any parts until they are found to be defective. I know they are cheap but its not in my practice. Thanks for all your help.
                  • tikalize
                    • Jan 2020
                    • 16
                    • U.S.A.
                    Yes budm those voltages are with main boad unplugged.
                    • tikalize
                      • Jan 2020
                      • 16
                      • U.S.A.
                      iam getting
                      .2v @ ps/on with main board plugged in in standby
                      3.3v @ ps/on with main plugged in Tv on
                      • tikalize
                        • Jan 2020
                        • 16
                        • U.S.A.
                        whats weird is at the test point j832 where it says 8v stb /13v on iam getting 11.5v and fluctuates to 10.5v in standby and 12.8v with tv on.
                          Paot #1
                          "Ps/on voltage drops from 4.49v to under 1v with power on and 4.49v in standby"
                          That does not look right, if the main board is connected and the TV is turned off, the PS-ON should be <1V, same for the BLU and OD pins.
                          Update I see your post # 11 for the PS-ON.
                            Originally posted by tikalize
                            iam getting
                            How about the OD and the BLU PINS?
                            • tikalize
                              • Jan 2020
                              • 16
                              • U.S.A.
                              Main board plugged in
                              OD= .2v On
                              0V Standby
                              BLU= 0v On
                              0v Standby
                              I dont know if it matters but the backlights are disconnected during these test or i hear arching.
                              • tikalize
                                • Jan 2020
                                • 16
                                • U.S.A.
                                I believe the circuit involved for producing the 4.49v for standby on the power supply is damaged by the short and reads fine until the main board is plugged in and puts a load on it or i have a shorted main that loads up a good power supply. But should the main board have any activity on PS/On pin in standby that will cause it to be low?
                                  PS-ON os for controlling the power supply board, when TV is off, the PS-ON will be kept low (<1 V) by the main board so the 13V power supply will only puts out about 8V for keeping the main board alive, when TV is turned on, the main board will let the PS-ON go high which then the power supply is fully turned on so the 8V will go up to 13V.
                                  So the PS-ON signal is fine, which you already reported on post #11.
                                  When the TV is turned on the OD and BLU should go high, but they are not at this point per your report on post # 15.
                                  • tikalize
                                    • Jan 2020
                                    • 16
                                    • U.S.A.
                                    Ok so if Ps/on is fine then should i be looking at the fact that power to the main board in standby is high around 11.5 and not 8v?
                                    • tikalize
                                      • Jan 2020
                                      • 16
                                      • U.S.A.
                                      Also what could be the cause of voltage problems on OD and BLU. Thanks you are giving me great info.
                                        It may be that the switching circuit (8V to 13V is damaged).
                                        Did you remove the power supply board and inspect the backside?
                                        But the thing is that in your post #1:
                                        At that state when TV is off, the PS-ON is low and with main board connected the standby did go down below 10V, correct?
                                        Can we see the good clear pictures of the whole backside of the board?
                                        Beside, when the 13V is present when TV is turned on, the TV should function normally since it has the required 13V to fully run all the functions.
                                        In this TV instead of having 5V STBY power supply and the second power supply for the 13V, it uses only one power supply for the main board that switch between 8V (TV off to save power) and the 13V when TV is fully on to save money.
                                        BTW, when TV is turned on, do you get switched 12V to the T-CON board?
                                          09-07-2024, 05:50 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
