Best practice for soldering a Flyback Transformer
  • Hitto
    • Apr 2019
    • 95
    • Italy
    I'm trying to solder a flyback transformer back to its board. It is quite heavy and the PCB is battered by age.
    Well:
    There are at least 8 solderable pins and two screws which secures (or at least on paper, please read below) the transformer onto the PCB.
    This is a reference picture:
    I already had to reflow some pins once.
    Who do you guys think would provide the less stress for the pins?
    1) Screwing the transformer onto the PCB and then solder;
    2) Solder the pins and then screw the transformer
  • petehall347
    • Jan 2015
    • 4427
    Re: Best practice for soldering a Flyback Transformer
    screw it first
    • llonen
      • Sep 2014
      • 495
      • hampshire
      Some of those pins along with land areas of the pcb will have high a thermal mass, aim for the lowest temperature for soldering if the copper lands are damaged. As a side note you need to ensure your soldering system has good thermal reserve so you are able to complete the rework in a timely manner, goes without saying used leaded solder.
      • Hitto
        • Apr 2019
        • 95
        • Italy
        Would it be better to screw it first?
        • R_J
          • Jun 2012
          • 9553
          Screw the flyback to the board then solder the pins.
          • Hitto
            • Apr 2019
            • 95
            • Italy
            Thank you.
            Having a hard time even fitting it with screws (it lays unevenly, one side with more distance between trafo and board). No wonder it developed bad solder joints.
            I am afraid that everytime you move that CRT some solder points takes a lot of fatigue according to inclination angle of the monitor itself. Very strange since other monitors are just better (just solder, greater pads, not screws but sturdy plastic hooks).
            Been thinking about adding grommets on one side and add epoxy on the center, between trafo and PCB, which is quite frustrating and will make it unrepairable in the future. Not to count that it takes hours for epoxy to cure.
            Any suggestion is warmly welcomed.
            • R_J
              • Jun 2012
              • 9553
              Is this the original flyback transformer or a replacement? Did it originally have mounting screws or was it just held in place by the pins?
              It is not uncommon to have poor solder connections on a flyback, or any transformer etc. Due to the larger pins they don't always get enough solder when they are manufactured. and since they have a larger mass and do vibrate at the horz. frequency the connecions get loose over time.
              • retrotechrestoration
                Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
                by retrotechrestoration
                I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
                Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
                03-22-2024, 06:50 AM
              • bohaboha
                can a flyback transformer for USB charger isolate?
                by bohaboha
                can i use a flyback transformer from an usb charger to isolate galvanically a small diy led tester? or it must be an isolated transformer
                01-15-2022, 02:36 PM
              • ttmi100x
                HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                by ttmi100x
                Greetings everyone,
                I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                Upon closer inspection...
                07-31-2024, 06:36 PM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
                ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 04:40 PM
