Panasonic TX-50AX800 HD HDMI ports no signal but on the 4K HDMI limited input
  • Samui67
    • 9
    Hello again,
    for getting a spare mainboard for my TX-58AXW804 i made a deal and catched a cheap TX-50AX800 with the same A-board (actually all boards inside are the same)
    Unfortunately there is no signal input shown on all HDMI inputs on this TV.
    The 4K HDMI input is working but only limited. Means, that only 4K signals are displayed. With all other resolutions eg. 720, 1080, 1366 or 3D Full HD content on this port, coloured vertical lines are shown on the display. All other functions of the TV are ok.
    Could it be related to the T-CON board or is it again related to the A-board?
  • Samui67
    • 9
    Re: Panasonic TX-50AX800 HD HDMI ports no signal but on the 4K HDMI limited input
    Meanwhile i checked the video signal path. Also replaced the FR Board with the one from the TX-58AWX804 and tried the factory reset procedure several times. No changes.
    The service self check procedure is not showing any problem. The status of everything is ok. Really don't know how to go on now.
    • supravit2000
      PS4 fat has inconsistent signal after HDMI replacement
      by supravit2000
      Hi, guys!
      I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
      My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
      12-19-2022, 08:08 PM
    • Xristakis795
      samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
      by Xristakis795
      hi to all
      i have the above model ue40d5003
      the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
      when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
      when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
      Can you tell me from your experience...
      02-09-2023, 03:17 PM
    • rp748
      HP E233 display HDMI no input
      by rp748
      Hi
      The display is working great except for the HDMI. VGA, DisplayPort is fine.
      i have tried several cables and sources with no luck.
      Board number is 715G8912- but i didn't find its schematic anywhere.
      The main chip is RTD2526FR which i didn't find its datasheet as well.
      Main board looks fine without any blown components or soldering issues.
      When an HDMI source is connected the screen goes blank for a few seconds and then it says, "HDMI is inactive" and enters to sleep mode.
      Tested Components:
      HDMI...
      09-02-2023, 10:05 AM
    • natiz
      Samsung UE65MU7003U / BN41-02568B - HDMI No Signal
      by natiz
      Following a power surge, the HDMI ports on a UE65MU7003U no longer work, no matter the port or the source - it shows No Signal.
      The other functions work well (eg Netflix app, etc.), its just the HDMI ports.
      Is the BN41-02568B board salvageable? Any leads before I open the heatsink cover? board replacement?...
      09-12-2024, 03:52 AM
    • japlytic
      Not all TVs can handle surround sound on a HDMI input
      by japlytic
      With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
      So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
      08-31-2022, 10:09 PM
