Curved TV LCD Panel Removal
  • Bloopeta
    • Jun 2018
    • 526
    Just wondering if there is any difference removing the LCD panel from a curved TV?
    I am no stranger to removing LCD panels, I do a few replacement backlight jobs a week, but have never had to do a curved before.
    I have just gotten a laurus ph-55curveuhd that requires a replacement backlight array.
    Are there any tips / tricks / special methods involved where curved TVs are concerned please?
  • neilc6
    • Nov 2015
    • 1550
    Re: Curved TV LCD Panel Removal
    Repaired a Haier curved bad backlight and it was just a flat panel pressed into a curved chassis. Salvaged a Samsung curved and the panel was formed curved.
    • Bloopeta
      • Jun 2018
      • 526
      Ah, so there are differemt types.
      Just being 55", with a flat panel I usually use a large bit of cardboard to keep it rigid, would the same apply with the curved?
      • neilc6
        • Nov 2015
        • 1550
        Based on tips previously posted, I usually keep the tv vertical when removing the panel and lean it against the back of my couch. With a large curved panel, this would be the optimum way to remove it since you won't be able to use suction cups.
        • Bloopeta
          • Jun 2018
          • 526
          The worst part about it is, I cant find any info on what replacement array I need from the make and model number, so Im going to have to strip it to get to the strips, order them and they will take atleast a week or two from China, so i either need to store the screen out, or put it back together, then take it out again when the parts arrive, doubling the risk :/
            https://www.badcaps.net/forum/showthread.php?t=81842
            • brucetv
              • May 2015
              • 281
              • united states
              You can use suction cups on a curved panel. Samsung in most cases we have seen is just a flat panel that lays down in a curved Tv bezel and the weight of the panel allows it to bow and lay in the bezel when you lay it back down. In most cases their are no tape or panel holders in place to hold the panel in so keep the outside trim bezel on until you get the tv turned over to hold the panel in.
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • HelpMeRepair
                Dell 34 Curved Gaming Monitor – S3422DWG display panel
                by HelpMeRepair
                Hi im looking foward to find a dell s3422dwg display panel , mine is cracked and im i cannot find it over the web , if you have any clue let me know , thanks
                02-23-2024, 11:11 AM
