LG 55EC930V OLED Is panel OK?
  • lin4sm
    • Sep 2011
    • 67
    Re: LG 55EC930V OLED Is panel OK?
    I have small workshop in my house.
    There is an old oscilloscope in my storage. I do not know if it is still working. Never used it just turned it on once 3 years ago. I did forgot a little how to use it as last time used it 15 years ago in University.
    I can try something with it only tomorrow afternoon.
    • Diah
      • Feb 2013
      • 6370
      there are test for the Panel to terminate if we have ONE OLED cell or row Cell had short ( regards to the time of use ) and some time it help too to let shorted cell to be OPEN so the panel will pass the over clock to let the system goes to protection mode.. need to do exact as written
      1- disconnect the Main boards from Power supply totaly and from T-CON too.
      2 as you did SMPS test before... need to do it same. as
      a- standby coneccted to PS on
      b- standby connected to panel on
      you take cable 12 volts pin on socket 201 and connected direct to F! on T-CON
      also it mean. the T-CON will have 12 volt from the cable you add to F! and 24V from the socket 202 at power boards.
      here when you plug the tv in wall socket... mean its going on and the panel on too with out main boards as its out from the system
      on the socket of LVDS at T-CON side... you can check after pin 10 to 20.. they will be as following
      10 will be P 11 will be N and so on till 20
      if you have signal generator or do it your self by take av signal from any source.. the minus of signal goes to chassis of the set.. and the P signal pin you can connected to 100PF ceramic cap and the next pin of cap goes as test pin to any of the mentioned pins as remarked with ( P )
      screen could show one color or many.... doesn't matter how it look as we want to see the cells turn on and force them to turn on.... if one shorted by test it will go open... ( mean it will be small white dots.. if one row shorted... then no chance,,
      any screen you will have shoot photo and upload here
      actually this is workshop test... but you can give try as it will not harm the set as well the main bards because its out from the system
      good luck
      • lin4sm
        • Sep 2011
        • 67
        I want to double check that I would not make mistakes.
        In the photo I have market where I will connect 12 V.
        And I will need to test screen on pins that I have marked in red square, am I right?
        Is it OK to use external power supply for 12V?
        • Diah
          • Feb 2013
          • 6370
          1- the 12 volts point correct on F1
          2- the test points correct...but you can skip them if you had at first turn on one color screen
          3- you can not use external Power. it should 12 V from same source of the PWB which supply the screen driver 24v. if you in case used before out source 12 then you had toasted the driver... hope you didn't lol
          • lin4sm
            • Sep 2011
            • 67
            I haven't used external power supply. It would be more convenient, but... thanks for letting me know.
            Had some food. Now I am happy to proceed with testing.
            • lin4sm
              • Sep 2011
              • 67
              #26
              I've got test pattern when turned power supply on. Did not do test points.
              I get green, red, blue, white, black screen. All colours has specific distortion, see attached photos.
              • Diah
                • Feb 2013
                • 6370
                i read before you get out the cooler silicon from the T-CON IC.. put it back, and be sure the ribbon cable you you before disconnected are sitting in place.
                then let the test run again. keep it running for at least 30 minute to clear cells
                you should after time to see the one color will be clear as the red screen but on all scree.
                at this condition .. yours panel / T-CON don't need signal (P) test
                • MixyourMind
                  • Jul 2016
                  • 10
                  • Austria
                  #28
                  Good morning and Happy New year. Any update about the panel revival? I am curios if it works.
                  • xmandarkx
                    • Dec 2013
                    • 54
                    did you have any luck? i have the exact same issue.
                    ive tried lots of things so far, i need to make the ir thing and try that next. just cant get anything on the screen.
                    • jotaerre
                      • Apr 2016
                      • Portugal
                      #30
                      Change the oled panel.
                      • romulus123
                        • Jun 2015
                        • 8
                        • Belgium
                        #31
                        I have the exact same problem with a 55EC930V.
                        Here is what happens with the "self-test" procedure explained by Diah.
                        Should I try to replace the T-CON or can I consider that the OLED panel is dead ?
                        Thanks !
                        • Diah
                          • Feb 2013
                          • 6370
                          half dead.. LOL
                          • Oled_gambler
                            LG OLED; Component-level repair on OLED panel?
                            by Oled_gambler
                            So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
                            one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
                            Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
                            Looks like the actual panel is at fault. I can...
                            11-22-2024, 03:58 PM
                          • WiredRacing
                            Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
                            by WiredRacing
                            Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
                            I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
                            The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
                            The LCD...
                            08-31-2021, 09:42 AM
                            Gigabyte AERO 16 OLED BSF-73DE994SO Notebook Specification for Upgrade or Repair
                            This specification for the Gigabyte AERO 16 OLED BSF-73DE994SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73DE994SO boardview and 16 OLED BSF-73DE994SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-07-2024, 06:38 AM
                          • howardc64
                            LG 49UJ6500 LCD panel lighter band that goes away
                            by howardc64
                            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                            02-19-2023, 12:13 AM
                          • Storyteller12
                            QN55Q60R Service Menu Panel Help
                            by Storyteller12
                            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                            01-13-2024, 01:57 PM
