Phillips LCD - Static on A/V source
  • R_J
    • 9588
    Re: Phillips LCD - Static on A/V source
    That interference does look like the video signal ground is missing. When component video is selected, did you plug the video signal into the Y or green component input jack?
    The video signals go from the a/v jack board to CN702, through the power supply board traces (no components) to CN302 which connects to the digital board, and goes through a 0Ω resistor and a .1µf cap and into the Zoran ic.
    • Diah
      • Feb 2013
      • 6435
      from his first photo of the AV source the menu text look clear and the noise at JPEG back ground. its tell the problem at the source not the set. out put signal from the source need to change between YGBR to RGB. also the resolution of the signal... and all screw of boards chassis need to be in place too.
      • caphair
        • Nov 2011
        • 1249
        I tried both Y and green in component and no image from either one. If I ohm test ground of av connector to ground of board and chasis it's 0 ohms
        • caphair
          • Nov 2011
          • 1249
          But the same source on another tv looks clear. Could still be a source problem?
          • Diah
            • Feb 2013
            • 6435
            sure.. TVs brands / firmware design handle AV signal in different ways.
            play with your source signal setting as i mentioned above.
            • caphair
              • Nov 2011
              • 1249
              #26
              Just tried there are no settings from the source. It's a handheld nintendo emulator type with games. No settings to adjust
              • caphair
                • Nov 2011
                • 1249
                #27
                I think you’re right. Just found another source that uses av and picture is clear. Should have tried before but didn’t think it was a source issue.
                Do you think those av to hdmi upscaler converters would clear it out?
                • Diah
                  • Feb 2013
                  • 6435
                  I think you're right. Just found another source that uses av and picture is clear. Should have tried before but didn't think it was a source issue.
                  good to hear you had proofed its source issue.
                  any HDMI upscale converters with out source power supply could do good jobs..
                  converters with out out source power are useless.
                  • Lvsitano
                    Asus X532FL 3.2V at source and gate
                    by Lvsitano
                    I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                    First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                    I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                    First...
                    06-26-2024, 02:13 PM
                  • Kanini Technology
                    Lenovo V15 Password Clear
                    by Kanini Technology
                    Hello I Need to Clear this Bios Password
                    LENOVO V15 IIL GS44D GS54D NM-C711
                    I Write another to password cleared But Hdd Not detected
                    So Pls Need to Clear this bios Password...
                    06-28-2025, 05:21 AM
                  • LarrySabo
                    Samsung ProBook NP767XCM-K1CA battery connector replacment source?
                    by LarrySabo
                    Tonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
                    12-04-2024, 09:10 PM
                  • Imdeksn99
                    ASUS fx505gt rev 2.0a bios request clear ME
                    by Imdeksn99
                    Need a bios laptop turn on but no display
                    its 8Mbits Files
                    bios is
                    W25Q80EW 1.8V 8M-BIT​
                    NEED HELP GUYS
                    OR PLEASE CLEAR ME for me thank YOU
                    11-24-2024, 02:52 AM
                  • tofik
                    MOSFET equivalent K8A60DA
                    by tofik
                    Hello guys,
                    I have a shorted MOSFET K8A60DA with the following characteristics:
                    Type Designator: TK8A60DA
                    Marking Code: K8A60DA
                    Type of Transistor: MOSFET
                    Type of Control Channel: N -Channel
                    Maximum Power Dissipation (Pd): 45 W
                    Maximum Drain-Source Voltage |Vds|: 600 V
                    Maximum Gate-Source Voltage |Vgs|: 30 V
                    Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                    Maximum Drain Current |Id|: 7.5 A
                    Maximum Junction Temperature (Tj): 150 °C
                    Total Gate Charge (Qg): 20 nC
                    Rise Time (tr): 25 nS
                    Drain-Source
                    07-19-2023, 05:18 AM
