Sony Mainboard Repair
  • bstewara
    • Jun 2019
    • 40
    Does anyone out there that know of a tv repair service that can supply and replace the processor in a Sony main board?
    Model # KDL-75W850C
    Main board A2071514A. BMX
    I have had no luck in finding a replacement board for this unit.
    Thanks in advance
  • Diah
    • Feb 2013
    • 6562
    Re: Sony Mainboard Repair
    this is Android TV correct? why you want to replace the Main IC ??? you may describe the issue you have so we could help you to identified the issue more close
    • bstewara
      • Jun 2019
      • 40
      Yes this is an android based system.
      It was Diagnosed by a repair center in Tucson who explained that they thought it was the main processor.
      Their term was a corrupted processor.
      They were unable to get a replacement processor for the repair. ( also they the repair center had not replaced this item before as well)
      The original failure mode was ( set was stuck in boot mode then detiorated to no pilot)
      Anyway I finally found a replacement board yesterday so crisis averted.
      Thank You for the response
      • TechRepairOutpost
        • Jan 2021
        My KDL-75W850C looks like it has processor issues, It boots to Sony Logo, then powers down, and doing the 3 blinking red lights
        Can someone confirm that that would be the issue?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4538
          • Italy - Milan
          This is a software problem, hard to get rid of but possibile..
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
