samsung un55hu8550f dead,
  • milleradam37
    • Apr 2018
    • 12
    hello all i have a samsung un55hu8550f, with a main board that has bn41-02205b as part number? anyway, the unit is dead if i disconnect the powersupply board from the main brd then the backlights do come on, i tried to plug back into main brd and disconnect other connectors one at a time to isolate problem, i pretty sure the main brd is bad, just wondering if anyone knows a component level fix for this brd looks like a used one is $150, which will make this a very unprofitable repair, any help appreciated,
    thanks
    Re: samsung un55hu8550f dead,
    You will get a lot more help if you upload good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
    • Unspun01
      • Jun 2011
      • 341
      If you are interested in component level repair, place your multimeter in continuity/diode mode. Touch leads together. Does it beep? Good.
      Now place leads across the +/- of each surface mount capacitor. Measure any persistent shorts? These caps are connected to power rails and may highlight problems on a specific voltage rail.
      Also with black lead on chassis ground, touch any lead of all surface mounted coils. There are many on your board labelled 3R3 or 1R0 or 1R5 or 4R7. These coils are connected to power rails, and any short circuit to ground on these components will highlight a possible problem with a voltage rail.
      Note that these components themselves are rarely the issue, but likely a transistor or IC connected on that power rail.
      Another thing you can do is to use a hot air dryer to heat the large heat sinks or other BGA ICs and then plug in and power on.
      If you find no shorts, and heating the board for a few minutes doesn't allow TV to show any sign of life, then you will need to start pulling datasheets of marked ICs and see if there are other shorts from VCC to ground, etc.
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
        09-07-2024, 05:50 AM
      • JSin21
        Compatibility of main boards between different variations of samsung MU6100
        by JSin21
        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
        I have Samsung Smart TV UA65MU6100WXXY version DA01
        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
        11-27-2023, 04:54 AM
      • elpatxi_bcn
        Samsung HG75EJ690UB Hotel TV, change main?
        by elpatxi_bcn
        Hello!
        I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
        Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
        The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
        05-19-2023, 03:21 AM
        09-06-2024, 11:40 PM
