LG 42PJ550 continuously clicking?
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Hi guys,
    I've got a LG 42PJ550 that went down on me over the weekend. The symptoms are it just keeps clicking and won't start. It was intermittent for a few hours and would cycle on and off and randomly start. Now it won't start at all.
    I bought a repair kit which included 2 x 22ohm resistors for R927 & R929, a voltage regulator for IC301 and a diode for D304. I'm also waiting for some SMD resistors to arrive which is another 'known fix'.
    I'd like to bow to the alter of the experts here and ask your thoughts... any voltage checks I can do to narrow it down? Etc..
    I hope the attached photos are OK.
    Thank you.
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Re: LG 42PJ550 continuously clicking?
    Any suggestions?
    • R_J
      • 9625
      You likely have a short on either the Y-sus or Z-sus boards, and not a fault with the power supply. Disconnect the plug going to the y/z boards and check what the Vs voltage is coming from the power supply.
      Also you could check if you have a short or very low resistance across the Vs pins on the Ysus. also check for shorted fets on the y and z boards.
      You can also use the SEARCH and look up your model to see other threads that might apply, there are a lot.
      • Loz2212
        • Jan 2016
        • 61
        • United Kingdom
        Hi R_J,
        Thank you for the response - I'll check what you have suggested tonight.
        I've absolutely hammered the forum over the last few days and was looking at everything power supply related... they seem to be plagued by a few specific faults on the PSU so I gravitated towards that.. I did disconnect the sus boards (only one connector comes out of the PSU for them) and the fault stayed the same. I've not measured anything yet with the multimeter but I intend to tonight.
        Thank you.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Check the 2 big white resistors on the top right side of power supply. They should read the same(10 ohms).
          • Loz2212
            • Jan 2016
            • 61
            • United Kingdom
            Hi Timmy,
            I've replaced these resistors already (the attached photo was before I did the work). R927 & R929 in the top right are 22Ω. All seemed to test OK anyway but they were in a repair kit I bought so changed them out anyway.
            I'll have another look tonight
            • Unspun01
              • Jun 2011
              • 349
              Loz2212 :
              Sometimes the large copper coils on the Y-sustain and Z-sustain boards develop poor or intermittent solder joints which can cause problems, but this issue is isolated by disconnecting the boards from the power supply, so suspect power supply.
              Testing power supply:
              TV unplugged, capacitors discharged, SUSTAIN BOARDS DISCONNECTED from power supply:
              Using TV chassis as ground, measure resistance/continuity to VA and VS pins on power supply connector with red multimeter lead. Any low resistance will highlight a possible short circuit and tell you which circuit is the issue.
              TV plugged in, power button pushed, SUSTAIN BOARDS DISCONNECTED from power supply:
              Using TV chassis as ground, carefully measure voltage of Va and Vs with red multimeter lead. Do you get a voltage, even momentary?
              The repair kit should have two ceramic resistors, IC301, diode D304, and possibly a fuse? you did not mention replacing the fuse?
              Double check orientation of installed diode D304 and IC301. Double check your installation for good soldering, and no solder bridges.
              • Sisko
                Onkyo-593 No power and now clicking sound
                by Sisko
                Hi all!!
                Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                10-03-2025, 02:18 PM
              • B0r1s
                Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                by B0r1s
                PSU - BN44-00878A
                Symptoms:
                The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                A weak clicking sound was coming from the transformer.
                Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                Progress:
                After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                01-17-2023, 04:58 PM
              • slimmy182
                [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                by slimmy182
                Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                Looking on google I found this:...
                01-14-2023, 11:55 AM
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
              • mikelu53
                Samsung UN60D8000YF Clicking BN44-0432A
                by mikelu53
                I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
                The set was working then not,then started clicking.
                Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
                Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
                A schematic or suggestion would be great.
                01-21-2023, 03:14 PM
