LG 50pc1d help required
  • Gary G
    • Nov 2019
    • 5
    Hei guys I have an LG50pc1d which decided to switch off.
    Unplugged and left for a day it would switch on and last about 2 minutes before switching off.
    I checked out this forum and tested voltages etc. NO ac detect all caps looked good and inside tv was clean no dust etc.
    I bought a power supply from eBay and connected it up, all looked good.
    On powering up and using it all seemed fine then it powered off after about 5 minutes.
    Left it unplugged for a few days and it powered up, I did the menu on remote and tv and checked the fan settings tempo was 20 degrees, low temp 50 high temp 60, fan off 20 degrees.
    It stayed on for about 15 minutes, the temperature climbed to 26 degrees, no fan on then powered off.
    The LED on the front goes from red then flashes 8 times and powers up on flash 9 then powers off.
    Any ideas or do I strip it for parts and sell on eBay?
    Cheers in advance.
    Gary
  • Gary G
    • Nov 2019
    • 5
    Re: LG 50pc1d help required
    Anyone after a 50" plasma to fix or spares?
    • Unspun01
      • Jun 2011
      • 345
      Hi Gary:
      These old LG plasmas often fail due to heat. There are a couple of culprits:
      1) Power supply has bad capacitors (they will look visibly bulged).
      2) The IPM (Integrated Power Modules) on the Y-sustain and Z-sustain boards usually fail as short circuit and prevent TV from turning on at all.
      The fact that your TV does turn on and work for a few minutes could be a power supply voltage mis-adjustment.
      You said you replaced the power supply. If you replaced the power supply, you should verify that the voltages for Vs and Va being output from the power supply match the required Vs and Va voltages published on a sticker on the back of the plasma panel itself inside the TV (near the top).
      If your power supply is putting out voltages that are too high, this could cause TV to shut off after a few minutes.
      The VS and Va voltages can be adjusted by turning potentiometers on the power supply board.
      Is this something that you are comfortable measuring or adjusting?
      • Gary G
        • Nov 2019
        • 5
        Cheers for the reply I'll check the voltages. Fingers crossed.
        The TV did produce quite a bit of heat even when new.
        The caps on the original PSU all looked good.
        I unplugged the Y and Z boards and the fault persisted, hence renewing the PSU.
        I'd rather fix it as its too bloody heavy to carry and too big for my car to take to the tip!��
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          I have a 50PC5D and a 50PX1D already broken down and on the shelf
          They call me......."threadkiller"
          • Diah
            • Feb 2013
            • 6376
            over all TV which had installed FAN in it... any FAN if the rm slow down it will give high resistances to let the TV shut down.
            open all fan and clean them or oil the shift of them..ot install new one i guess PC one will pass
            • Gary G
              • Nov 2019
              • 5
              Diah I was just going to post the fix!
              Yup, it was the fan!
              I stripped and cleaned it and the tv is working perfectly.
              I checked the system and there were 171 fan faults
              Thanks for the help guys
              • Unspun01
                • Jun 2011
                • 345
                Awesome news! No need for new power supply at all. And no need to carry heavy TV. Best of luck.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Good idea mate well done! I've had these pc1d sets with piles of dust stored in the fan.
                  • Andreas_de
                    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                    by Andreas_de
                    Hello!
                    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                    04-12-2025, 10:38 AM
                    03-31-2024, 02:12 PM
                    07-01-2024, 06:34 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • timtrace
                    Won't stay powered on - Sharp LC52LE700UN with RDENCA336WJQZ DPS-286AP power supply
                    by timtrace
                    Greetings - first post. I'm awed that a forum like this exists. It's a dream come true. I'm not even kidding.
                    I've got a 13 year-old Sharp LC52LE700UN television that's developed a problem of powering itself off after 30-45 seconds. If I pull the mains cord and reconnect, it will come back on right away without so much as a button push...then turn off after 30-45 seconds.
                    Service manual S37X3LC46E77U is attached to this post, as well as a front and a back picture of the RDENCA336WJQZ DPS-286AP power supply taken after completing my work.
                    Each time that the...
                    05-14-2020, 09:24 PM
