LG 42" 42LD550 start up.
  • Pukehead
    • Nov 2018
    • 25
    Re: LG 42" 42LD550 start up.
    ok, will do.
      • 12269
      • U.S.
      Good video there on testing voltages and voltage regulators etc: https://www.youtube.com/watch?v=ocqnqmBxiqY
      • Pukehead
        • Nov 2018
        • 25
        I got 1.4 Kohm.
        Also, last night i tried to update the software. I plugged in the USB stick and nothing happened. I went to bed and when i got up, The backlights were on and the red led was steady. TV appeared normal.
        I turned off the tv, unplugged the USB stick and turned TV back on. Same issue.... no backlight, led pulsing.
          • 12269
          • U.S.
          Did you do some of the testing in that video, voltage regulators etc?
            • 12269
            • U.S.
            Probably the same old problem with the bad bga in the LG tvs, could try heating or cooling the bga then plug tv in and see if it trys to work or anything.
            • Pukehead
              • Nov 2018
              • 25
              Yes i did all that early testing.
              I tried heating up the board with a hot air station. Just not sure where it needs the most heating. IE what IC/ SMD?
                • 12269
                • U.S.
                #27
                Guess we need those good clear straight shot pictures of the whole back and each board.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  The main processor, under the big heatsink in the middle.
                  • Pukehead
                    • Nov 2018
                    • 25
                    Ahh. That one. That thing runs hot even in STBY mode. Should i take the sink off it to heat it up?
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      Yes, take it off.
                      • Pukehead
                        • Nov 2018
                        • 25
                        Ok i will try that tonight. Do you know what adhesive is under it in case it doesnt stick back on?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Yes, a few adhesives can be used, I wouldn't worry about it for now, there is a possibility the processor is already dead.
                            • 12269
                            • U.S.
                            #33
                            Big problem if the bga is hot in standby.
                            • Pukehead
                              • Nov 2018
                              • 25
                              So i tried heating up the main chip. Back-light works but i get no menu, sound or anything that resembles an input signal. I ordered a used board off the bay. Hope it works. I'm also going to try and cool the chip better maybe a bigger sink or a fan.
                              • Pukehead
                                • Nov 2018
                                • 25
                                Thanks guys for all your help.
                                  • 12269
                                  • U.S.
                                  #36
                                  Cool, let us know how it goes.
                                  • tennno`
                                    RCA LED46C45RQ,Sound but no Back lights
                                    by tennno`
                                    Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
                                    Has All voltages coming from main board.No voltage going to
                                    Back lights from power board.Have no Schematic.Back lights work when
                                    Led Back light Strip tester is used.Tester shows 110 volts from each
                                    side.Also if you use the side controls and use the vol +or- tv shuts
                                    down.
                                    Thanks for any help
                                    04-10-2022, 03:34 PM
                                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                    by sam_sam_sam
                                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                    I am comparing them to a brand new one that I installed
                                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                    I going to let it run for several days before I remount back on the wall next to the...
                                    09-05-2024, 06:48 PM
                                  • Musictuff
                                    70UH6350 Back lights
                                    by Musictuff
                                    My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                                    04-09-2023, 11:45 AM
                                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-12-2024, 02:30 PM
                                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
