Sky HD box DRX780
  • John843883
    • Nov 2012
    • 71
    Sky HD box DRX780
    Anyone repaired the PSU in one of these and if so is there anything I should be checking before powering it back up again?
    I've replaced all of the failed capacitors including the Rubycon ZLH's and I came across some odd schottky diodes with very high reverse leakage current Sanken "RA13" which had me stumped for a bit.
    Nearly all the capacitors on the PSU tested bad but not all had visible signs, one day it just failed to even enter standby. Is replacing the capacitors all there is to getting these back up and running again or are there other things that fail once the multiple voltage rails have been messed around by bad caps? The Sky viewing card slot went a bit finicky in the weeks leading up to it failing too.
    Thanks.
    Re: Sky HD box DRX780
    1) Lets see the pictures of what we are dealing with.
    2) Did you test 'RA13' off the board or still connected to the circuit?
    3) How high is the leakage current?
    4) What is the applied Voltage to the RA13 to obtain the leakage current reading?
    • modtool
      Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
      by modtool
      Dear members,
      I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
      I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
      The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
      When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
      01-15-2024, 08:56 PM
    • gurj1979
      Surface Laptop 1769 SSD Failed KUS040202M-B000
      by gurj1979
      Hey guys,
      I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
      These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
      AliExpress has this but it's expensive.
      Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
      Or which NVMe can I remove it from ?
      02-17-2025, 04:02 PM
    • test.it
      Failed bios update on a Dell Precision 3650 Tower
      by test.it
      Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
      01-28-2025, 07:32 PM
    • l0lhaxz1
      QN65QN90A - Mainboard MLCC failed - now bootloop
      by l0lhaxz1
      Hi
      I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
      Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
      Came to learn after a bit more research...
      02-06-2023, 08:59 AM
    • TheDJVG
      Lenovo NM-B891 (X390/T490 etc..) failed PU1001
      by TheDJVG
      Hi everyone!
      Got a Lenovo X390 with a NM-B891 motherboard. When USB-C connected it negotiates 12v without any problems but no current is drawn. Inspection of the board shows this failed component:
      Based on the boardview I was able to find this is a MP86901. I've removed this component and cleared the pads.
      Connecting the charger again shows no improvement (12v, no current).
      Resistence around this component (near the CPU) measure around 2.1 and 3 Ohm, probably acceptable for the location of the components being CPU related?
      So far...
      06-29-2024, 10:13 PM
