looking main board
  • birdfeed
    • Apr 2014
    • 9
    • usa
    looking main board
    searching for a main board. good or defective.
    Olivia 747-B11.
    The unit has a bad ic which is causing a short. I can't locate the main nor
    the ic. Even part of the board that has that ic.
    sco-p508201-s10. main board. defective ic is Q108 8 leg ic.
    back of board by connector j55.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: looking main board
    what is the part number written on Q108? Can you upload some straight shot, high resolution pictures, front and back of the main board?
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
