RCA DLP m50wh72s
+ More Options
Posts
  • Stang8URMPRT
    • Nov 2009
    • 6
    #41
    Re: RCA DLP m50wh72s
    The lamp only had maybe 200 hours on it wheb it first started acting up. It is a brand new Phillips.
    • Wizard
      • Mar 2008
      • 2296
      #42
      Call around and see if a shop have a test lamp so you can bring your tv in to test.
      Once in awhile bad lamp occurs.
      Cheers, Wizard
      • Stang8URMPRT
        • Nov 2009
        • 6
        #43
        Cheers, Wizard
        Alright! Thanks.
        • Lisa Su
          Samsung P2250W Hissing (Newbie)
          by Lisa Su
          I've been using this monitor for last few years.
          Symptom started by OSD menu popping on and off randomly by itself. So i tried to clean the touch control area with some cloth but it didn't help.
          After 20 minutes monitor started hissing from the back. And then 30-40 seconds later screen started fade off/on like as if i was turning down the brightness that's when i turned it off by power button (hissing stops) and replaced it with spare monitor.
          Today i opened up the monitor, excited to repair my first monitor (or big electronics) hoping it's a bad...
          03-07-2022, 05:58 AM
        • odonono
          Louis Rossman style repair shop for regular laptops?
          by odonono
          I made a post over on reddit about how my windows laptop only works when plugged in now, because I dropped a screw driver on the connector pins where the laptop battery plugs into, causing sparks. I put a brand new battery in but still the same result, so something on the board obviously got fried (however, there's no visible burn marks, so no clue what was affected). I honestly wouldn't care, but my laptop is power throttling even with the internal battery unplugged (turns out this is a common problem on laptops with poor batteries or missing batteries). The GPU won't go above 40W when the TDP...
          03-06-2024, 07:31 PM
        • badcappo
          Dead Thinkpad E15, hissing noise from BQ25710
          by badcappo
          Hello there, got a Thinkpad E15 on the bench, almost no vital signs. Only things: Power button white LED flashes several times when USB-PD gets connected (number of flashes varies from three up to twelve times, sometimes no reaction at all). Battery charge indicator LED stays orange. Most interesting is hissing / whining sound from Battery Charge Controller IC BQ25710 on the keyboard side of the main pcb. Board fuses tested and intact, no shorts found so far. BQ25710 is also the only thing on the board to become warm in thermal image (below 70 °C). Thanks for any hint.
          03-09-2025, 08:23 AM
        • Kartowl
          philips 47pfl6158k/12 image faded away, sound still coming from TV
          by Kartowl
          Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
          04-23-2024, 12:57 AM
        • link626
          Klipsch computer subwoofer speakers hissing buzzing. Does this look like bad cap?
          by link626
          Klipsch 4.1 computer speakers hissing.
          Looking at all the caps on the amplifier, they all seem flat, except one maybe.
          Not sure if this is leakage, or factory marker pen.
          Can you tell?
          The speaker system recently developed nonstop hissing noise. after 22 years.
          Is there a special kind of cap I have to buy?
          Low ESR? or general?
          I see these for sale.... Panasonic FC 47uF 50v low ESR radial Capacitors caps 105C New low impedance...
          08-02-2022, 06:38 PM
