Samsung P2250W Hissing (Newbie)
  • Lisa Su
    Badcaps
    • Apr 2021
    • 216
    • Taiwan
    I've been using this monitor for last few years.
    Symptom started by OSD menu popping on and off randomly by itself. So i tried to clean the touch control area with some cloth but it didn't help.
    After 20 minutes monitor started hissing from the back. And then 30-40 seconds later screen started fade off/on like as if i was turning down the brightness that's when i turned it off by power button (hissing stops) and replaced it with spare monitor.
    Today i opened up the monitor, excited to repair my first monitor (or big electronics) hoping it's a bad capacitor issue after googling a bit.
    When i looked at the main PCB there was indeed 1 1000uF/16V bulged capacitor with small leakage. So i took it out and replaced it by one with the same value from old PC mainboard. Replacement cap measured 995uF, bulged cap measured 540uF on my multimeter.
    I assembled the monitor and turned it on but it's still hissing. Picture still showed up though.
    Now i disassembled it again and tried to see which component is hissing by powering it up. Sadly i couldn't tell it by hearing and am kinda scared to stand my ear close to this for too long. It sounds like pressure cooker and feels like something is about to explode, lol.
    Anyways, I think it's obviously out of my skill level. But i'd love to see thoughts/suggestions from experienced members.
    Here is a video of hissing
    https://streamable.com/qyav7l
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Samsung P2250W Hissing (Newbie)
    Agreed that is a weird sound!
    My bet would be on either one of the transformers (if it is then that is probably no problem).
    But more likely that big bulk filtering capacitor has an internal fault, never heard something like it though!
    What you can do is use a long plastic straw to listen better for the noise.
    But do take care, heatsinks are commonly at live voltage!
      09-07-2024, 05:50 AM
      by momaka
      03-15-2023, 10:17 PM
    • keepread
      Dell monitor PSU vs Dell laptop PSU
      by keepread
      Hi there!
      Someone gave me their old monitor, it's Dell S2715ht.
      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
      10-30-2025, 04:45 PM
      09-06-2024, 11:40 PM
